yes, it works only with hdmi connection. it won't work on component out put and no hd on component.
I have the pack till 2013. I sent a mail to their CEO and CTO , got a call this evening the guy said he is calling from the CEO office I explained him he said he will again call on Tuesday
Can you please give the email address of the CEO/CTO. We could also write to them and put pressure on them to resolve the issue ASAP.
I am telling as per the feedback from others on SOD!please explain this? are you sure that in TS hd DD works with hdmi?
Hehe, what was that??? Component output is ONLY FOR VIDEO! It doesn't carry audio unless you use the regular LR Stereo "composite" outputs with it!yes, it works only with hdmi connection. it won't work on component out put and no hd on component.
Hehe, you seems to be another member lost in the settings layout of TS/TS+HDDD is coming with HDMI? Then I don't know what I messed up..Still couldn't get
Strangely in TS User settings-> Sound Settings, Connection type is getting default to SPDIF even though I changed to HDMI. If I remove CoAxial cable..no Sound. Any comments???
Check above! You seems to be doing it wrong way. Its the same way you set the aspect ratio of SD TV! You need to first switch to SD there and choose 16:9 for your HDTV to get 16:9 output for 16:9 content and can choose stretch and pillarbox for 4:3 accordingly.^
you are not alone
for tata sky HD (non recorder) update did happened but works fine.. however everytime i turn it on .. it gives a pop-up of changing the resolution to get better quality even when its on 1080i
I got a call as promised by that person he said as of now it's gonna be 576i only and he will again call back 2morrow with more information with Tech Team.
Rohit and all
Suggest you all to send a mail so that they take this serious. email id's of CEO and CTO are give in my above post.
I am little confused here..if output type is SPDIF, how will it be from HDMI? Have you tried removing Coaxial cable and check the audio?Bingo!!
I'm getting perfect DD5.1 sound from HDMI on my TS HD plus. In sound settings I've got
Output Type = SPDIF
Preferred Audio = Dolby Digital
/Alok
Satya,
I've taken only HDMI connection from Setup box this time. Alhough I've tested with the coax also and it works well on that too. Seems Tata Sky has enabled SPDIF and HDMI Both and you can get DD5.1 on HDMI as well coaxial at same time.
/Alok
Bingo!!
Output Type = SPDIF
/Alok
I wish Airtel follows the same route. They are total junglees.........![]()
Any one wanna swap the TS HD box with Airtel HD?:licklips:
