No HD after software update in Tata sky HD
i am talking about getting dolby digital through hdmi,not video,now i need both hdmi and spdif(for DD), because with only hdmi i am getting only pcm
i dont need hd through component
yes, it works only with hdmi connection. it won't work on component out put and no hd on component.
DD is coming with HDMI? Then I don't know what I messed up..Still couldn't get:mad:
Strangely in TS User settings-> Sound Settings, Connection type is getting default to SPDIF even though I changed to HDMI. If I remove CoAxial cable..no Sound. Any comments???
I have the pack till 2013. I sent a mail to their CEO and CTO , got a call this evening the guy said he is calling from the CEO office I explained him he said he will again call on Tuesday
Can u please send me the email of ceo so that i can tell them my problem as the tata sky engineers have no clue.
I got a call as promised by that person he said as of now it's gonna be 576i only and he will again call back 2morrow with more information with Tech Team.
Rohit and all
Suggest you all to send a mail so that they take this serious. email id's of CEO and CTO are give in my above post.
for tata sky HD (non recorder) update did happened but works fine.. however everytime i turn it on .. it gives a pop-up of changing the resolution to get better quality even when its on 1080i
please explain this? are you sure that in TS hd DD works with hdmi?
I am telling as per the feedback from others on SOD!
Hehe, what was that??? Component output is ONLY FOR VIDEO! It doesn't carry audio unless you use the regular LR Stereo "composite" outputs with it!
Hehe, you seems to be another member lost in the settings layout of TS/TS+HD :D
There is NOTHING as DEFAULT there, you are doing it wrongly, you just have to switch to "HDMI" option and change the setting below it from PCM to DD and SAVE IT! Should work then if you have TS HD (as indicated, doesn't work on TS+HD).
you are not alone
Check above! You seems to be doing it wrong way. Its the same way you set the aspect ratio of SD TV! You need to first switch to SD there and choose 16:9 for your HDTV to get 16:9 output for 16:9 content and can choose stretch and pillarbox for 4:3 accordingly.
Let me know if you do get DD after setting it the RIGHT way :)
I believe your TV is full HD and thats the best resolution you should use. I also get that message when I hard reboot it, but thought I am getting it since I have an HD Ready TV and it wants me to switch to 720p.
@prankey
yes, i have done the "right way" as you say above.For getting DD i still need to connect through SPDIF port
also can u please point towards the sod thread where you found dolby is available through hdmi, when i checked there, they also say it is still only through spdif,
see post 53
http://www.saveondish.com/forum/T-tatasky-hd-new-software-pictures?page=6
edit: ok, i found it on post 56, however doesnt work for me
Same here. Also the audio is Nat Geo HD is not proper. The dialogs/narrations comes through the rear channel.
Rohit and all
I have emailed them so lets see what happens !
Bingo!!
I'm getting perfect DD5.1 sound from HDMI on my TS HD plus. In sound settings I've got
Output Type = SPDIF
Preferred Audio = Dolby Digital
/Alok
Bingo!!
Output Type = SPDIF
/Alok
I am little confused here..if output type is SPDIF, how will it be from HDMI? Have you tried removing Coaxial cable and check the audio?
Satya.
Satya,
I've taken only HDMI connection from Setup box this time. Alhough I've tested with the coax also and it works well on that too. Seems Tata Sky has enabled SPDIF and HDMI Both and you can get DD5.1 on HDMI as well coaxial at same time.
/Alok
Satya,
/Alok
Thanks..I just checked removing CoAxial. Working fine. Output Type setting couldn't stay in HDMI..hence the confusion.
Bingo!!
Output Type = SPDIF
/Alok
Also one extra setting in audio which was present on SD box but missing in HD -
Preferred Audio Level - used for default audio level on power cycle.
Yes I got a call from Mr Nityanand form CEO helpdesk they are getting many complaints for this issue and he consulted their tech team which is working itseems.
More the mails and escalations they will fix it soon.
I wish Airtel follows the same route. They are total junglees.........:mad:
Any one wanna swap the TS HD box with Airtel HD? :o:licklips::D
