2011 Samsung Plasma 3D PS51D550
Guys - I recently bought Samsung 51D550 with the help of Prankey..
I also did buy Wharfedale 10.7 floorstanders, 10 CM, 10 DFS surround, Powercube SPC-10 package..I am excited to setup my tv and speakers..
Now I m trying to test initially my floor standers. I have a problem with ARC from 51D550 to Onkyo SR608 amp. I connected HDMI v1.4 cable from HDMI2 (TV) to HDMI out (Onkyo). The moment I switch on the TV, i am taken to HDMI2 showing a blue screen. I can see receiver volume and setup option in TV display. I have enabled ARC in receiver and also in TV (HDMI CEC and Anyshare). Now, I can control my receiver volume with TV remote as both are CEC compatible. But I am not getting the sound to my speakers connected to receiver.
Am i doing something wrong here? Please advice..
The firmware is available on the UK site. Honestly, not sure if you can apply that. Try contacting Samsung on their tech helpline.
Also try the Off-Low-Off cycle suggested in the article.
Guys,
Can someone please confirm the best price for SAMSUNG PS64D8000FR (64 inch plasma) ? Is it advisable to wait till Diwali ?
Hello All,
This might be duplicate as I had posted it in more generic thread. Repeating here at proper thread.
I had my Samsung PS51D550 is delivered yesterday ... So far all signs say that its fresh piece... (fingers crossed )
I've checked -
1. Box seals,
2. All buttons for fingerprints, smudges, dust etc and its seems clean.
3. Also checked all ports for connector marks but they seem clean and new.
4. Also out of the box tv was not having any region, date or tuner setup.. So feel that its fresh new piece.
Question - How to check usage hours on this model? Please help
Thanks ...
Keeping the setting low "actually" works, but if we turn off the TV and switch it back on, it reverts to the older settings.
I even upgraded the firmware to 1020 indian version. The TV does not even recognize the UK version (1024)
1020 is of not much help.
Found an issue with my TV. After just 1 month it shows Image retention for Airtel DTH logo at bottom of the screen.
All the retention/burnin protection has been on since the day TV was purchased.
Even i have it on my tv . i run scrolling for 8-10 hrs every night from last 10 days it has reduce by 10%.god knows when it will go .
Hey Prankey, what to do? I am thinking of booking it tomorrow and now i am reading it has IR and burn in issues. What to do dude?? As a backup please tell me what price you can get for 46D6000 3d led.
@Prankey What should i do? Should i go and book 51d550 tomorrow? Or should i buy 46d6000? Tell me dude, having IR or burn in issues would break my heart.
I have 42B450 plasma which is like 1.5 years old.. The TIR was present for the first 6 months.. Now it is barely a problem.. No burn-in anytime..
Yes that is what I feel. Madhav went with 51D550 as a difference of around 18k for 46D6000 without freebies (D5100 with the usual 4.5k extra). I also know that image retention might be an issue during the first few months before the phosphors mature and do not leave any residue after about 200hours of run in. IR usually never happens after the TV goes old and as per the feedback from other members across forums and professional reviews, its significantly improved with 2011 Plasma models of Samsung.
Madhav - take out all the doubts in mind as if IR be an issue with your TV we can always replace/take refund from Samsung and go for another model.
I am also trying to crack a deal for Panasonic and LG models. I tried meeting the sales head at Devi, but he had left by the time Madhav's transaction was completed. Will try reaching him tomorrow on the same.
I will start a thread for the D5500 BR Player for 9.5k which can easily be shipped across India without any issue of risking damage.
Hey does anyone know how to change the aspect ratio of video while playing from usb? Screen fit option seems to be disabled when playing from usb. I want to play 2.35:1 videos in 16:9 stretched format for the first 200 hours as its recommended not to have letterbox till break in period.
I think you can change it from a menu which appears after pressing the "Tools" button on your remote. I don't exactly remember the menu item name...
Hi Prankey,
i was following the thread from the day it started for a good reviews from all the owners to finalize and pick up the one along with the price thread offered by you.
Clarifications required for me:
1. About the Image Retention
2. Power Consumption
3. 3D Playback using PS3 (Image Retention is the playing a game or movie by other sources MM Players Western Digital and others)
Please reply back in detail..
Thanks,
Jagadish.
If i go to menu -> picture settings, there the option Screen fit is there but is disabled when playing from usb.
I will try the tools menu today.
I have scouted all over the internet to read literature about Image Retention and Screen Burn from the past few days as i bought 51D550 plasma and here is what i found out from experts and also analyzing comments of normal users :-
1) First 100 to 200 hours break in is a "necessity" for any plasma as it fundamentally necessary for the way plasma technology works. (Newer plasmas are have a lot less risk but still its better to do atleast 100 hours)
2)IR and Screen burn in modern plasmas occur only by "extremes" and not normal use. Thats why most people never notice it.
3)"Extremes" in plasma terminology means having a static image for hours and hours at end and doing the same for days. Static image might be just one part of the screen like the network logo or HUD in a video game or worse the welcome screen of a dvd player left on by mistake. Also to some extent the black bars in top and sides when watching a 2.35:1 movie in letterbox mode or 4:3 in letterbox mode.
4) Screen burn in risk is reduced by more than 90% after "break in" period of the plasma
5) Newer plasmas might sometimes have Temporary Image Retention but almost never Permanent burn in !
6) All companies including Samsung & Panasonic DO NOT COVER IN WARRANTY THE DAMAGE TO PLASMA TV DUE TO SCREEN BURN IN OR IMAGE RETENSION (It is specified in the first page itself of the manual which came along with my 51D550 Plasma TV)
Break in Method:-
(Very simple but takes a couple of weeks or a month max, then we can enjoy 10-15 years life of the panel)
* Reduce the brightness and contrast below 50 and choose "movie" mode or equivalent ( Burn in and IR almost never occurs when contrast and brightness is low)
* 80% of the time watch 16:9 content. (Do not watch 4:3 letterbox mode and try to avoid 2.35:1 as much as possible and stretch all videos to 16:9)
* Run the Scrolling screensaver(built in almost all modern plasmas) or other break in screensavers all through the night so that you can reach 100-200 hours fast.
* Ideally 10 hours break in a day would be gr8 (8 hours scrolling screensaver at night and 2 hours of viewing)
*Do not spend more than than 10% of time playing video games, watching CNN,NDTV etc or channels having Ticker or ESPN etc having fixed scoreboard until 100 hours and 30% until 200 hours.
*Even if watching above, switch channels during advertisements and while playing video games take a break for 5 minutes after every 20 mins.
*Use as much of 3D as possible(Except 3D gaming) for 200 hours !! 3D has a lot of activity and gives a lot of exercise for the phosphors as it has to display 2 frames in the time of 1 and also because 2 slightly different images are being displayed, the possibility of burn in is drastically reduced.
* Avoid using it as a PC monitor. icons, taskbar etc not good for plasma. ( If you want to use tv as a pc monitor much of you time then avoid plasma altogether )
I know this is seems a bit technical but once we do all this and break in the plasma in 2 or 3 weeks or a month max then we can enjoy incredible picture and gr8 3D and big screen and gr8 value for money !!!
Note:- Do not let people who do not know about these things handle your plasma during initial 200 hours, also educate your family members. Most simple thing is to tell them to change channels during an advertisement so that network logo does not get retained. Tell them to change to Doordarshan as it has logo on the left side while most channels have on right side, so changing to it during advertisement automatically gives protection against burn in.
