Audiodoc
A picture speaks a thousand words (and prevents carpal tunnel syndrome).
TC
TC
For the cabinet check here.
@keith: this looks promising and I know the place. Will speak to them Friday. The 'industrial" looks of the cabinets is quite nice. Hope it looks good too in real life.
Thanks,
Joshua
Dinrack will drill the holes to your specs. I was in talks with them but lost patience once when their drawing expert did not come up with a verison for days. Otherwise they are your best bet for a good chassis. They are not too keen on custom colors though and will try and push whatever is available.
---G0bble
Torodial Transformer x 1 - 24-0-24, 5A, 240 VA (Mircale M22550 225VA, 2 x 25V, 4.5A or SV Tronicks)
Last week I collecteda pair of Standard Kit and I partially populated one board. I am new to DIY, so it took me some time to match the components, but with prompt help from Siva, able to complete it. Appreciate his effort and patience in pursuing this to benefit many of us. I have no knowledge (dont ask me any technical questions), hence cautiously moving forward. The assembled PCB is shown below.
I have to now source the remaing components (see list below). I appreciate if any one could point to any reliable shops in SP Road (Bangalore) for the same and also the approx. price for these components. Some suggestions such as Arihant, Chetan and Advanced Micro Components on SP Road, I have noted those. In case anyone has additional info, please post the same.
- Caps x 4 10,000 uF (Panasonic)
- LM3886TF x 2
- Volume Pot x 1, spec (50k?)
- Torodial Transformer x 1 - 24-0-24, 5A, 240 VA (Mircale M22550 225VA, 2 x 25V, 4.5A or SV Tronicks)
- RCA Chasis mount x 2 pair
- Binding post x 2 pair
- IEC Power socket with inbuilt on/off switch x 1
- Heatsink x 2 - what size? 10" x 2" ?
- Heat sink paste
- Other miscellaneous items such as lug/tag/fast-on connectors, wires, screws etc.
Hi I have found some items on element14
Caps 10000uf PANASONIC | element14 India
LM3886TF NATIONAL SEMICONDUCTOR|LM3886TF|AMP, OVERTURE MUTE 68W, 3886, | element14 India
RCA Chasis mount Audio / Video | element14 India
Binding post Binding Posts | element14 India
IEC Power socket Power Entry | element14 India
Please crosscheck with Siva before buying.
Sachin
Hi Sachin,
Can an individual order from element14, or is a company registration required. Sorry for the off topic.
The price on element14 looks to be on the higher side than SP Road too.
Joseph
You have to buy from Shopping.kitsnspares.com just copy paste element14 part no on kitsnspares.
The prices are on higher side,because all are imported parts.
Did you source enclosure for this?
Sachin
- LM3886TF x 2
- Heat sink paste
I am also going to make the same amplifier. Premium kit will be reaching me soon. I already have a 25-0-25 220VA toroid, heat sink and 4 10000 mfd capacitors. And enclosures are on their way. Already have good quality binding posts.
The ones available from element 14 are costly. Try MX electronics ones.
From where did you get the kit?
Premium?? Can you share the details?
Yes got the premium kit from linuxguru costs twice the regular kit. Includes high end capacitors, resistors. Cav you send me the details of the R-core transformer form Hyderabad. I wanted a few R-cores.
