Dear All,
Recently i moved to another place ,i had to leave my old Sony speakers ,now i brought another set 5.1 Sony speakers with Sub which are used one.they are small speaker will post pics later don't have cam with presently and unfortunately on the speaker model number i cannot see.
I tried watching HD Avatar and BATMAN ,sound really didn't impressed please advise how to fine tune.
presently i followed bellow setting for the receiver.if any posts all ready there on the forum please direct me or advice for fine tuning .
Area 6 'X14' ,and connected sony 5.1 ,onkyo nr-609 ,play on mini ,all are connected through HDMI ,SPEAKER cables used VDH THE TWIN.
.Speaker THX audio setup
turned on THX Ultra 2 / Select Subwoofer
3.Listening mode set up BD/DVD
Analog / PCM Neo:6 THX cinema (other options All ch. sterio, PL II THX cinema)
1.Mono/Multiplex source set to Pure Audio ( i thought of music play)
2ch source set to Pure Auido ( i thought of music play)
Doly D/Dolby D Plus / True HD set to Straight Decode
DTD/DTS-ES/DTS-HD set to Straight Decode
Other Multi ch. source set to Straight Decode
Not sure if we start play any BD movie which option one will take from above settings.
4.volume display set to Relative (THX)
muting level -sigma dB
max volume +5dB
power on volume Last
Head phone level 0dB
5.Audio Adjust
LFE level
default is set to 0dB for all dolby, dts, dolby trueHD, DTS HD, DSD
6.Source Setup
Audyssey setup
Dynamic EQ set to On
Reference level 0dB
Dynamic volume Light
7.Intelli volume seto 0dB
A/V sync set o 0ms - my room is small just 8ft from i'll watch, any better settings suggest
8.Picture Adjust
Wide Mode set to Auto
rest settings are default
9.
Audio selector set to HDMI by default
fixed mode off
max volume +5dB
5.Audio Adjust
LFE level
6.Source Setup
Audyssey setup
Reference level 0dB
8.Picture Adjust
9.
fixed mode off
