KEF speakers
Quote from Profx, Mumbai on e mail.
Kef. Q300 - 01pair x 31,900/- Denon 1713 - 01no x 36,900/- Total. - 68,800/-
Bestprice - 63,296/- courier & octroi charges are extra.
LBT (Tax similar to octroi is 5% of billing amount in Solapur) and courier extra.
BTW hows this pricing?
That's a reasonable discount.
This means speaker cable should be minimum 14AWG or lesser (i.e.12 or 10), correct?
14 AWG is good to go, 12 AWG is supposedly better and 10 AWG is something I have come across only once on a forum. Beyond this, probably even the law of diminishing returns fails :) Don't get caught up too much over cables.14/12 AWG will suffice and simple HDMI cables do the job (My profigold was 650/- if I remember correctly). I would also recommend banana plugs as they makes it easier to attach/detach speaker cables and looks neater (to me).
The idea is to have clean connections and quality cables ... which is not necessarily an expensive route.
I can't stress enough the need to buy a pair of robust book shelf speaker stands for Q300. They contribute to the sound and are more than just "rigid" stands. So do factor in the price for those too. If you plan to keep Q300s on a platform such as wooden cabinet/table, the (lack of) rigidity of those platforms might limit the sonic capabilities of the speakers
hi,
Kindly suggest good compatible centre speaker, Woofer, surround for Denon 1713 and KEF Q300?
In what sequence these should be purchased?
Thx
Congratulations!. Did they give you further discounts to the quotations?
You can purchase the center for cinema set up. Try Q200.
is it must to use only KEF for centre and surround with KEF Q300?
Can we combine any other brand speaker?
