Netflix, my experience...amazing service!!! can be accessed from INDIA as well..:)
Re: Netflix, my experience...amazing service!!! can be accessed from INDIA as well..:
Guys signing up for NETFLIX using UNBLOCK.US.. As Credit card is required to signup for 30 trail, now is it safe to put my CC info on NETFLIX using UNBLOCK.US? or VPN is the best option?
Thanks..
Actually I used my credit card to sign into netflix. Though I cancelled my subscription within 1 month, I saw that they are still deducting from my credit card. And my unblock us account also expired.
I need to instruct my credit card company to block the payments to netflix.
Thanks..
UNblock and Netflix are two different things you need to have independent account in both to use the facility.
NETFLIX accepts Indian CC if you put a US valid address. UNBLOCK.us take any card any address.
The auto subscription on most of the sites are on by default (which is very irritating), when ever you subscribe to any site for any services, make sure always that the auto subscription mode is not checked, if it is you have to manually uncheck the option. This becomes even more complicated, with Paypal payments as the auto subscription is also active at Paypals website so even if you have disabled it from the merchant's website you still will be charged as you opted for paypal as the payment. In that scenario you have to go to paypal and disable the this option.
Hope this helps
Hi All,
Just came across these two websites which provides plugins for your browsers to unblock the region restricted sites -
Hola - Unblock censored sites with free VPN Proxy & Accelerate your Internet
https://mediahint.com/
All you have to do is install the plugin in your browser and start watching videos on the restricted websites.
I have been successfully watching BBC UK live videos from US, which was restricted otherwise, using the hola plugin.
You can try out accessing Netflix/Huluplus from India after installing this plugin.
It will save you money if you are using VPN services to watch Netflix/Hulu plus from India.
Let me know how it goes.
Cheers!
I was watching movies (super HD) of Netflix through Google TV box( Logitech Revue) for the past 3 months. Unfortunately the Revue stopped working from yesterday. Power is Ok and it responds to key board but blank screen. Tried to reset but is stops at the logo "GoogleTV- Logitech Revue" and the screen goes blank after some time. Any suggestions.
What is the alternative which is capable of Netflix and Plex applications.
Cheers!
already shared couple of pages back, infact on the first page itself if I remember correctly.
Ugh! I just added some redundant information then.
But it is indeed a very good option for people using HTPC/PC to watch Netflix on the big screen.
I watch live BBC UK everyday from US, using this.
Anybody have experience with Apple TV. I am unable to watch netflix after my googleTv stopped working. Thinking of buying Apple TV which has Netflix applications in built. Not sure whether it allows external applications like Plex.
What apple TV and why not WD TV Live .. ?
Hey Sam,
Last time you were speaking bout some settings for the browser so that HD works, could you share the same, i am using firefox for watching netflix on my pc. It seldom goes to 720p and keeps jumping between 480p and 720p.
oh its the buffer value, if for some reason the browser does not choose the optimum buffer value, you can do that manually. I think the shortcut is Shift+Control+alt+S or Shift+Control+alt+left click anything above 2000 is HD I believe.
Any suggestions on how I can improve the Netflix performance on my WDTV Live? Its connected to my LAN through WiFi and I'm just about getting 480P, with frequent dropoffs to SD quality
I have a 2MBps MNTL unlimited connection, and have a PogoPlug, Raspberry Pi and a couple of laptops connected on the LAN (however torrents have been paused, local minidlna streaming continues).
I think minimum recommended for 720p is 4mbps ......???
Damn, OK. Will have to manage with 480P, which is not too bad too. Is there any good 4MBps connection recommended? Want to drop my Tata Sky HD connection (6K annual fee), as I just watch some serials on Star World HD and some movies (that are also available on netflix). Budget is 2K per month
Depends what is available, At my location Airtel is good. Been using it for 7 years now. 8mbps connection is rock solid, no drops and constant 8mbps .... :)
I just cant live with FUP unfortunately :(
Going to find out if Tikona is any good
FUP will be there, unfortunately in almost with every ISP. With with my connection it is there, 250GB, which is good enough for me as my max ag d/l a month is around 180GB.
If FUP is not there then you will compromise with the speeds ...... total unlimited with speed more than 4mbps, I seriously doubt any isp will offer.
Sorry, which plan is this? Dont see this anywhere on the Airtel site - maximum FUP they offer is 175GB on 8MBps or 16MBps apparently. My usage will be around 180GB-200GB per month, so 175GB is just lower than my cutoff
Is that extra slot to share still available? How much is it per month?
That came as an offer to me on call, since I am a so called premium user for them ... :D ..
