- Joined
- Mar 11, 2010
- Messages
- 3,129
- Points
- 0
Thank you, IndianEars. I did notice these things. I've mentioned these in the compromises I had to make in the positioning. But using a mono switch is something I've never done at all! My amp doesn't have one, but maybe JRMC has this option. I'll try this out for sure![]()
My current speakers seem to be less sensitive to the rear wall in terms of bass than typical. I need to put them out quite a bit into the room to reduce the bass well enough to my taste.
I've previously used pink noise to do this, but I now use either spoken content, or "Ballad of a Runaway Horse" to setup the center image.
Assuming that you have the PSB B6 speakers currently in the chain, as learnt from your signature, can understand what your experiencing. Saying this as PSB speakers IMHO are more LF biased compared to others & when paired with a NAD amp this phenomenon is showcased even more! Is the DHT pre used with the power section of the NAD currently??? Do share your experience with this combination as well. Thanks
