The Giveaway Thread
...and was finding it hard to believe that we had not met each other...
Thanks to this wonderful forum.. have made a good bunch of like minded friends here !!! cheers... !!!
+1 to this. When I received a fantastic Panasonic HU from Kishna (Hydrovac), no body in my office(since I got it shipped at my office) could believe that it was sent by someone whom I have never met. They were totally blank when I told them that it was a giveaway!:)
Thanks to HFV. Have helped me know some wonderful people.
Saket
Here you go guys. My Belkin TuneBase iPod/iPhone FM Transmitter for giveaway.
The TuneBase is a combined iPod holder, charger and FM transmitter; you put your iPod into the holder, plug that into a cigarette lighter socket, and tune in using the controls, with the frequency shown on the screen of your iPod (it doesn't work with 3G iPods or other MP3 players).
The TuneBase is black plastic with an acrylic case, so it matches your car better than your iPod. Its sturdy and the flexible metal neck makes it easy to position the controls where you can easily access them from the driving seat (though obviously not when you're driving). It's heavier than an external transmitter, so the power adapter has extra protrusions, a rubber flange, and an optional size adapter to make sure it stays snugly in the socket. The connection is through the dock, so the TuneBase can control the iPod, saving favorite frequencies and pausing music when you unplug it or turn off the car engine. There's an option to switch from stereo to mono, and to adjust the transmitted volume - this is useful, as different iPods have different line out volumes; the Nano is quieter, for example.
Belkin TuneBase iPod FM Transmitter Adds ClearScan, Automatically Chooses Best Frequency | TechCrunch
Its in great shape however I have not tested this in a while. But I don't see why this should not work. If you are interested please write in. Prefer a Bangalore pickup.
Still available. No takers?
This might be the wrong thread.. but was checking if anyone had the following as spares -
1 - Optical Audio Cable (the one that fits PS3)
2 - Optical Audio to Digital Audio converter...
Folks, my first HTIB is for a giveaway. It is the JVC TH V70. The DVD player is not working but may be fixed. The sub and satellite speakers are available and may be used as components seperately I guess. This is for a pickup from my place in Bangalore, will not be able to ship it. Here are some pics -
A very close friend of mine wouldn't mind this for his Restraunt. However if somebody would like this for their personal setup please go ahead.
If no one I would like to give this to my friend.
I from BLR and have expressed my interest by PM.
The HTIB is reserved for Record Player since he was the first to respond! 007india is first on the wait list.
RP, please PM me to schedule a pick-up.
I have 4 Nos. of 4' X 2' DIY Glass wool Panel which I had made and used in my HT set up for trial purpose, Just exactly to ascertain how it really improves my room acoustics. In fact it was really superb so now decided to go in for permanent expensive stuff like Saint Gobain Echophon Glasswool blocks and make 4' X 2' panels and place them permanently in the optimum place which I localized with the help of my DIY panels.
So my existing Panels are for give away. They are with lining cloths only, so if the taker decides to retain them permanently then I would recommend covering with some nice curtain cloth or custom printed material, or else simply use this for trial purpose and get an idea later can be given to some one else.
Though it cost me close to 5 K to make still I feel shipping is not worth it, Hence local pick up is better.
R. Balagopalan
Bala: Would like to try this before I finalize mine. game?
I was just looking at my walls, and mentally measuring :cool:
I don't think I could make them fit. Maybe they'll find a permanent home with you, madbullram. If so, that's great. If not, maybe I could try...
