Excelvan CL720D Projector through AliExpress
Subbiya
Chennai, India.
I was searching for a low budget projectors and found some links in this forum.
Excelvan CL720D Projector:
https://www.aliexpress.com/store/pr...d-Projector-HDMI-VGA/1727764_32497019246.html
Excelvan CL720D LED Projector with Digital TV Slot-161.69 and Online Shopping | GearBest.com Mobile
UNIC 46:
UNIC UC46 1200 Lumens Portable Multimedia HD Mini LED Projectors Private Home Theater Cinema: Amazon.in: Office Products
I'm much interested in Excelvan than UNIC. Has anyone used aliexpress, how customs are handled? Also the price seems to be higher in aliexpress than gearbest. Please suggest some good way to import this item.:sos:
Thanks,
Subbiya
Thanks,
Subbiya
Did you manage to get the Excelvan?
Gearbest/Aliexpress?
How is the experience?
Thanks,
Ace.
It is better to spend few more bucks and buy a local branded projectors since ones you specified come with no support .
