captainrizal
Does adding power amp to an integrated amp which has a pre out make any difference to the sound quality? which amp remains dominant in sound signature? Need some help here.
Depends on which integrated amp you are using and which power amp you intend to buy.Does adding power amp to an integrated amp which has a pre out make any difference to the sound quality? which amp remains dominant in sound signature? Need some help here.
I have done this primarily , because my speakers are power hungry and in other words they sing better with more power.
If your speakers are not that power hungry then providing them more power will give you some extra headroom thats all..nothing much..![]()
who said more Bass is needed....more power translates into more headroom, dynamics and high frequency components get more current that was previously eaten by low frequency componentOr you may add an active subwoofer
Placement- without the subwoofer the speakers aren't producing the bass from the right spot either.Sub might do it but placement and integration can be a nightmare.
The Preamp Section Dominates the signature , Mostly the integrated effect will be prominent. Other aspects like bass, dynamics, resolution will improve depending upon the relative quality and power output differences between two amps. Overall you tend to gain even if you use the same series power amp.Does adding power amp to an integrated amp which has a pre out make any difference to the sound quality? which amp remains dominant in sound signature? Need some help here.
