Wow!! Saw the pics!!maybe 10 kg each incl the frame i think...
Definitely food for thought during house repainting.
Thanks for sharing.
Raghu
beautiful mpw...would be a pleasure to listen to music in this setup. whats your listening position ?
mpw, awesome. I like the way you have integrated the panels with the decor. They don’t look out of place. A long time visit is still pending![]()
There's no scientific reason that comes to my mind why it would be applicable for horizontal surfaces and not for vertical surfaces.@keith_correa
I am aware but i thought / read - from GiK website - it was more for ceilings..
will re-check ..
@keith_correa
will re-check ..
Yes sir
Sure.Guys, I am going for beer. If you want me to report on that, I will![]()
Not true. If only it were so simple. The short truth to this is that this depends mainly upon the frequencies one is targeting, the absorption material used and the density of the absorption material among others.There is a suggestion that 6 inch is too thick but i have read that an absorber starts to really work after 4 inch thickness so i selected 6 inches - which is greater than 4 inches and doesnt get too big aesthetically as well.
I wish I had a wise gut like yours. All my gut tells me these days is to get out, exercise more and to reduce my gut!I made the absorbers first as my gut feel told me this would be of benefit - this would be better than diffusers behind the speaker.
