Pardeep Bansal
I also thought digital media is not affected by copyingdint know copying digital files affected the sound
If you are referring to:@alpha1 Please check the previous posts of this thread for the conclusive explanation of the poll.
The above is one of the observation, I was talking about insight into all observations.Therefore, on a general perspective, people who did not perceive a notable difference is roughly double (actually 1.8 times) than the people who marked the difference. That means the majority of the participants (roughly 2/3rd people) can not hear any notable difference, even after 10th copy and in spite of read error in some rips. This can be noted as the outcome of this test.
Why have 25% of people preferred 01.wav and 03.wav over 02.wav and 04.wav?@alpha1 All the files are bit-imperfect. Therefore, every files are different to each other. It can be "seen" through various tools, but can not be "heard" notably by majority. You want to know the reason for it - was it your query?
BDW, similar situation can be found during other types of disk copy. I have discussed this phenomenon earlier in a post in this thread.
Poll or Test
.... It's like a very tough IIT JEE mains question that only 10% get right. Now that 65% didn’t attempt it or 25% got it wrong doesn’t change the right answer. Because, it was a test and a not a poll to begin with.
as per (minimum) 90% participants POV, the samples' degradation could not be differentiated "in a proper manner" by listening only
The title of the thread by itself clearly says "A Blindfold Test", so it's a "test", no matter we make out to be.Once we say ‘as per’, it becomes ‘an opinion’. Again we get into the ‘poll’ territory. Semantics matter.
We can only say ‘90% participants could not differentiate on a proper manner by listening only’. I’d imagine many of those who didn’t get it right also believe the degradation can be differentiated, though they weren’t able to in this instance.
Only the voters can explain it.Why have 25% of people preferred 01.wav and 03.wav over 02.wav and 04.wav?
It is a Test in a Poll format. Rest are nicely explained by our FM @bhaskarcan, many thanks to him. Similar tests on different topics are in the pipeline. Hopefully, I can execute the next test very soon.The important question is 'Was this a poll or was this a test'?
The analogy is incorrect. Data CD's (not the media per se) are different from audio CD's. The "extraction" process is different. Look up "seek jitter".<snip>I have told earlier in a post of this thread that similar situation can be found during data CD copy (like Windows or MS-Office Setup disks). In that case, after so many generations of CD copy, the occurrence of a failed disk is rare, in turn, installation did not corrupt too.
I just want to add that the outcome of the test depicts that the "Change" (I would like to use the term "change" over "degradation" at this point of time) can not be aurally picked up correctly by the majority of the voter. Yes, there is "Change" happened during CD copy which can be identified by visual file checking tools. Still, the change is probably either so minute or corrected (possibly by error correction algorithm of the audio CD), it remains way higher than the threshold of listening pleasure. I have told earlier in a post of this thread that similar situation can be found during data CD copy (like Windows or MS-Office Setup disks). In that case, after so many generations of CD copy, the occurrence of a failed disk is rare, in turn, installation did not corrupt too. Therefore, it can be considered that, despite the minute difference, audio CDs can be copied without losing the substantial-quality that hampers our listening pleasure.
Hearing capability - yes, that's why we have this test to get a range of people voting. Anyone joining this forum - we can assume that he/she will have a certain minimum level of hearing and musical understanding else they wouldn't have been here, forget participating.It all depends on the hearing capability of the listener and the system he or she has. Your sample size is insignificant to arrive at any conclusions. If one can’t hear the differences, great. If one can, so be it. Ultimately you have to decide whether you find any differences or not.
So to understand this test betterIMO, this test is relevant only for the rips. The results would have been more relevant or it would have got a better result of what people can hear, if the test involved CD copy 10 vs RIP of Original CD.
I guess with the same set of people who voted, the results would be different if it were a test between original CD & Rip from Original. What this test essentially proves is it doesn't matter whether the files are ripped from Original or CD copy 10. A rip is a rip & lot of people can't make out the difference.
But there are many times it has been proved(may be wrong word but what I meant is if google there so many blind tests) that, not all but lot of people, can differentiate between a rip & CD.
I am noob so please take my comments with as much salt as you could afford.![]()
Unfortunately playing a cd through player and cd rip via dac doesn't have the same electronics.Sorry If I miss understood. This files in this test are from Rip of Original CD & Rips from CD copy N.
what I meant is, if it is Original CD(played through a CD player) vs RIP of original CD (played through some transport connected to a DAC), most of the participants from the same group would have identified/noticed the differences. And IMO, CD would have won by lot of vote margin.
Are you talking about retesting the hypothesis with slightly changed procedure? It can be done. But the important factor is the "trend" of this test which you have already said. The trend clearly indicates that CD copy do not change the sound aurally. It can only be picked up visually.So to understand this test better
You would prefer a cd to be written(copy to copy) 10 times - then we have a rip and a original cd rip.
We can have 4 such files(rips from various copies) and the go for blind test. And your gut feel is people should be then be able to identify the actual cd rip.
Files - original cd rip, 10th copy to copy rip, 10th rip from eac and some other nth copy rip
I think it can be done @anirban420.. Your views please
