Local dimming test for h8g/U79
Just got done with the installation.
It mostly is a good out of the box experience but here are a few issues I had.
1. Had to change HDMI to Enhanced mode to get 4K to work on my Xbox. I wasted a good 15min wondering why 4K wasnt working.
2. It seems to be using a very old version of Dolby Vision(the one without dynamic metadata which is just HDR10) and my Xbox says that it doesnt support dolby vision. This is a huge bummer for me.
Here's a pic that shows the Dobly vision issue and also the blooming around text. It isnt as bad in real life as it looks on the pic.
@lightgamer
Played the videos you linked and the colors and black levels are excellent for an LED. I have a 55B7 OLED too and I feel like this comes within 10-15% of the black level. TV itself is brighter and that causes the colors to pop.
I haven't tweaked much of the settings yet so it might improve further.
This video is only in 1080p and playing it on YouTube shows a lot of compression artifacts.
Quantum TV is an idiot, he doesnt know what he's doing.
I do see some blooming but mostly when in the Xbox menu. Netflix and other normal content doesn't show any noticeble blooming.
Its pretty much the h8f and I dont think I can do a better job than rtings.Can you please do a detailed review?
Windows and Xbox are usually terrible with Dolby content due to the licensing restrictions around it.
If you have Netflix 4k plan, try playing 'our planet' on it with the default Netflix app (not through Xbox). It's a Dolby Vision title and should work.
I did. It did improve the picture.try these settings from rtings i know both run different os see if these settttings can help
Hisense H8F Calibration Settings
We used the following calibration settings to review the Hisense 55" H8F (55H8F), and we expect them to be valid for the 50" model (50H8F), and the 65" model (65H8F).www.rtings.com
I can answer any specific questions though.
I don't think its a licensing issue but rather with Hisense not updating their Dolby Vision package on the VIDAA platform
The Android version doesn't seem to have the same issue. I do have the 4K plan but I dont want to use the TV's internal apps(privacy concern with chinese mfgs).Netflix on my Xbox falls back to HDR10 and the experience has been pretty good so far.
Also, I am seeing some motion stuttering on 24p content on Netflix and I don't see an option to set Film mode. I had to resort to enabling motion reduction by setting blur and judder 2 which helps a bit. I'm really disappointed in the tweakability of the settings. Like the android version has so much more flexibility.
The TVs might be the same but I think Hisense is changing the hardware processing system.If this is 100% h8f then the u8080 would be 100% h9g
with no downgrades
do you have any other streaming device besides xbox?
Yes, I'm eagerly waiting for that one. My issue is not with Netflix itself, but with connecting the TV to the internet. I have a few chinese security cameras and you have to see how much data they send back to China. I had to block internet access for them.Google is coming with the new best chromacast which will support android TV. Also you can get the mi box I guess.
If it can play Netflix, then the app is made by Netflix themselves and you shouldn't worry about privacy. Netflix has strong DRM protection and won't allow others to mess with their apps.
Coming back to the point, even internal Netflix app when using the older version of Dolby vision is pretty much just going to be HDR10.
