May become a long one soliciting suggestions and advice.
Dear all,
Been passively reading this forum ever since I decided to set up an HT. Trust me I have read so much in the last three months, and now I am left with more questions than when I knew nothing and started over. So, I thought I would share my thoughts here and request suggestions and opinion from the veterans.
Quick details: Room size: 10x12; Aiming to build: 5.1.2; Budget: 3.5L-4L, all incl.
The space:
Like I said, it's a 10x12 room, with concrete floor, and block concrete walls, the long (12') sides of which will be shared with the living room on the one side, and the main bedroom on the other side. Flats above and below.
Have attached drawings of a few options. (Behind the recliners is a small work area. Also, I just saw one of those drawings say Gear Cabinet. It is not to house A/V gear, but motorcycle gear.
1. The first is a horizontal set up and almost everyone says it is not advisable.
2. The second is a vertical set up, and I did not like the problem the room door was posing.
3. So, got the okay from the home minister for the repositioning the door to open into the living room, so that the TV-LCR wall can be fully utilised. (I have drawn extra rear and ceiling speakers, which will be a later upgrade. So kindly ignore them)
Questions about space:
1. Can I go ahead with the speakers, set up the place and take a leap of faith that the sound will not leave the room - either to the main bedroom or to the neighbour downstairs. (Am a bit of an owl and, besides some 30 minutes of music in the afternoons, mostly play movies late in the night -- not loud, generally at 60ish dB with dynamic sounds touching around 75 dB) The sub I most likely will pick up is the SB Pro 1000.
2. Or should I just blindly spend the first money on sound-proofing the room and then start building the sound system as and when money is available. If I go down this route, could FMs suggest some good, affordable people?
I live in Mumbai, and currently have a rough verbal quote of Rs 550 per square feet including the window and door. (At 636 sq-ft of wall area, the cost comes to 3.5L)
Speakers:
So, I hope to set up a 5.1.2 within a budget of 3.5L with the following rough break-up: 1L for L-R, 30-50K for the centre channel, and 30K each for a pair of surrounds and ceilings, 75K for the sub, and hopefully 80K for the Denon X2700 if I settle on the Klipsch. If the final speaker demands it, then may have to bump up to the X3700.
I decided to go with floorstanders for their obvious advantages and also because commonly available stands bump up the price of any good bookshelf to that of an equivalent floorstander.
The rains have been bonkers in Bombay this month, and with the Covid restrictions, I have only so far listened to the Klipsch RP-4000F and 5000F so far. I quite like them. The main thing I noticed was that when I heard them I did not feel they were as bright as many say. The mid-range and bass were a world better than the RP-4000F. I really liked the RP-5000F. So, it's a definite option.
Once the rains abate and restrictions are lifted, I plan to request demos from sellers in both Bombay and Pune for the following speakers in my budget:
Dali Oberon 5, Paradigm Monitor SE 6000F, the Q Acoustics 3050i, Emotiva T1+, KEF Q550s, and the Focal Chorus 716s. And though it will shred my budget, I also hope to listen to the Martin Logan Motion 20i.
Questions about speakers:
1. Would you all suggest anything else that you personally like in this budget?
Finally, a couple of general questions:
1. Will this set up be an overkill for this room?
2. And, of course, the room sound-proofing, the cost of which will push back the project by a few months. But if it is the only way to ensure peaceful nights for the missus and no complaints from the downstairs neighbours, I will spend this first and look at the rest later.
Thanks in advance and look forward to what I know will be good advice from this forum.
Dear all,
The space:
Speakers:
