Congrats, Vivek! Nice pics too!
Could you comment on how quiet/noisy that CPU fan is, in a quiet room, under normal load?
Congrats, roc! When you get it up and running, could you say how quiet/noisy the CPU fan is, under normal load?
I was originally planning to use the
Asus E350M1-M PRO for my build. It has more expansion slots, and an eSata port & a firewire port (that the Gigabyte & MSI boards don't have). And, from reviews, it seems this board can be run with passive cooling (just that heatsink), without issues under most conditions; In fact the non-PRO version does not even come with the fan.
Unfortunately this board does not seem to be available anywhere. It is listed on a few websites (Indian) but nobody is getting back to me with concrete availability. My local guy tried to order it, but he says it is not available now (He's pushing me to get an Atom board, so I'll take that with a grain of salt). I'll get concrete information about the available/not-available status tomorrow.
So it looks like I'll probably be choosing between the Gigabyte
GA-E350N-USB3 or the MSI E350IA-E45 boards.
Could you guys help me with a couple of things?
1) I absolutely need to use an Asus Xonar Essence STX with the boards I choose. Are there any particular advantages/ disadvantages either of these boards have, keeping this in mind?
2) The Gigabyte and MSI boards are miniATX boards (actual size: 17cm x 17cm). The Asus board is listed as a uATX board (actual size: 24.4 cm x 18.3 cm). Are both miniATX and uATX the same standard? Will the Asus board fit into a
Silverstone GD-04? The cabinet's specs say it will take Micro ATX, Mini-DTX, Mini-ITX boards. I've already ordered the cabinet, so I'll have to suit the board to it anyway (sigh!). I've been assuming all along that the Asus board will fit into this cabinet.
3) @Vivek & @roc, if it is not too much to ask, could you guys measure the height of the cooling fan (from the base of board to the top of the cooling fan)? I wanted to know this because the cabinet I've chosen has a height restriction of 70mm from the bottom of the motherboard to the top of the cooling fan. Any taller, and I'll have to do away with the optical drive.
