Try to get amp. rated to drive 2 ohm loads. Very important, else you will not be capable of hearing tight low frequencies that the sabrina is capable of.
I have compared a pair of higher end amps. recently, luxman m700u and Symphonic line kraft, and the symphonic line is the clear winner. Consider the luxman m900u which is rated for higher current, but not sure if it will be able to match the symphonic line kraft (general impression I got from other forums is luxmans are not the tightest when it comes to low frequency ranges).
Also Dan dagostino classic series, boulder 1160, pass labs x series, and higher powered xa series will work well. All of these are available with indian dealers.
Excellent speaker, enjoy.
Sid
