Thanks mpw, but i am not looking for the standard type dome tweeter solution.FM Harshad had scanspeak D3300 tweeters foe sale.. Understand they are good ones..
Then use this ring radiator - Peerless XT25TG30-04.Thanks mpw, but i am not looking for the standard type dome tweeter solution.
www.bmsspeakers.com
www.bmsspeakers.com
4 way will be a nightmare to align even with first order crossovers. and there will be significant loving issues with using a crossover at 8k. would be much simpler to import the beymas and pay the duty.After 3 months of patiently waiting for the Beyma tweeters, i understand that these tweeters have vanished from all stocks. The Chennai beyma dealer is indifferent and does not respond to any messages. His silence speaks louder than words and he has ditched me on this. Thankfully i was able to get full refund for the advance paid and i am not hoping him to deliver the tweeters any soon. God be with you, if you happen to deal with such dealers. Anyway thats a different story altogether.
Now, i have to redesign the 3 way speaker and have some ideas. 4 way come to my mind as i could not find any single tweeter (other than the Beymas) that can handle from 2kHz to 20kHz. I have narrowed upon some compression drivers + Ribbon tweeters combo to take this task in a 4 way setup. So the frequency division will be somewhat as below,
20Hz - 300Hz - Seas woofer
300Hz - 2KHz - Satori MR
2KHz - 8KHz - compression drivers (yet to decide between Paudio and Selenium-JBL)
8KHz - 20KHz - Fountek ribbon tweeters.
Interestingly Prem's JBL 4343 was an inspiration of taking this idea and the vanishing of the Beyma's allowed me to think like wise. Yet everything is still under design stage and i have not ordered anything. I have already discussed this with the FM for whom this is been built and he is quite ok with this approach.
Thanks for looking.
I may go 2nd order or probably 3rd order after measurement. Not sure how much lobing will affect as the CD will be in a horn. Will plan a horn for the fountek too if i go that route. beymas dont seem to available to import too - i have checked that possibility. import cost is staggeringly high with one site - shipping is the killer.4 way will be a nightmare to align even with first order crossovers. and there will be significant loving issues with using a crossover at 8k. would be much simpler to import the beymas and pay the duty.
Kannan, thanks for sharing, the peak above 15KHz is a point to consider which looks annoying at the moment. The phase plug on top of the dome could be a source of resonance though i am not sure.If you are looking for a wide band tweeter with good power handling, the ScanSpeak Illuminator R series is very good.
ScanSpeak Ill
Keith, thanks for suggesting. Somehow Peerless drivers never got adjusted with me so pass it this time.Then use this ring radiator - Peerless XT25TG30-04.
Decadent_Spectre, thanks for your suggestion. Will have a look at them and decide appropriately.Might I humbly suggest -
Coaxial Compression Drivers
www.bmsspeakers.com
www.bmsspeakers.com
mpw, i had done a NF measurement of the satori and i found 1120Hz and not at 1.5kHz as dip as per my microphone. This was measured with the microphone almost touching the dust cap. I won't worry too much about that if i am not able to measure at 1 meter or the far field listening position.Hari
In the satori midbass there is a dip in response at @1500 Hz..
How is this being tackled ?
Thanks for your insights, i shall check the Troelsgravesen article to know more. IMO, mic will pick up anomalies better than my ears and so a slow sweep won't help much in my case to find out issues. I think its the peaks that we need to worry much than the dips in the response.While I have looked at different satori designs especially at Troelsgravesen...I find this dip a bit disconcerting...
Maybe I am not in the same league as you perhaps in speaker building..
Ideally u want to hear everything...than not hear something which the mic doesn't pickup..
Did u try a test time say from 1khz to 1.5 kHz slow sweep ?
Is it an optical illusion or does the tweeter baffle angle outwards?
Also, that step under the tweeter is bound to create diffraction - let's hope it's not nasty.
IME such efforts are more hype than substance in general, though i have not used them to accuse. Let me see if someone can listen those unevenness.fyi.. Troelsgravesen charges about Euro 100 per pair of midbass to apply some coating which apparently smoothens the response at that freq..
cant say about TG's attitude but $100 for a coating is huge by any standards.Troelsgravesen doesnt suffer fools - it is quite evident from his website and his attitude.. and that comes from huge experience.
I dont give much importance to dips if its not more than -3dB. In my measurement it looks like more of a cone resonance than response issue. I think that will go off after the driver is break-in for 100 hrs.The point i am trying to make is that TG has used these same mid bass drivers despite the response dip at approx 1.2 khz
but i do not understand how is the design compensated for this dip..
There are ups and downs - it will never be ruler flat but generally this midbass can be taken higher IMO..
