Karthik, Panny 220 is the only blu-ray player I am aware of that can be made 100% region free by an update. Again, why do you have to worry this? most of the discs you get here are region free.
Vinay, If you buy it from India, the price is cheaper. Last when I checked, it was retailing for USD 199 (12,000 INR) where as it is available in India for around 9K. yOU WILL GET 220 V too.
the carpet that's going to suit the wall colour.
Neutral tones like browns and greys or combinations of those are better than reds or blues.
@OP, Are you going to paint the walls or doing acoustics?Also, paint should be in the flattest sheen possible to reduce glare and reflection from the screen if you're using a projector.
