Prem,
Welcome to the world of dedicated entertain met room.
It is very good that you like DIY instead of taking professional help.
In general there could be certain things for which the solution is not coming rightly therefore i am sure you will not draw a deadline to finish the room's work because it may create a havoc with the end result.
It is very important to get the things rightly with your planning and do take help of fellow members. However good may be your ideas, please do consider to share on the forum because who knows some of us may throw better solutions and so on while we can also learn from your ideas.
Th scree size you may be able to get more because the speakers will not obstruct the screen much unless you plan to watch movies in 4 X 3 though they are few in such formats.
V.
V.
I am building a dedicated HT room on the terrace, right now masonary work is going on and the contractor gave me an estimate of 5-6 Weeks for the entire room.
I am a DIY kinda guy and would build the setup with advice from you guys. My room layout is 17 feet by 10 feet. If I leave half a feet each side for speakers, I will have a 9 feet screen size.
Prem
