Some advices are required on the audition and buying of the system. It may appear to many of you as silly but it is imp: for someone who will be doing it for first time for the item on which he/she is not an expert.
What all the points to check/ remember during audition and where in Mumbai it is possible?
What should be the criteria for the showroom for better audition?
Is there any trusted site (name pl.) from where you can buy online?
Is it advisable to buy imported system with voltage/frequency differences with India?
Out of your 100% budget how to divide the amount for AVR and speakers?
Is there any way to know that you are not getting original system when you are going cheaper deal?
What all the points to check/confirm before finalizing the deal.
Pl advice and add if Ive missed something as far as to get a great home theater within budget.
