Centre Channel Speaker Suggestion
I am planning to upgrade my centre channel, at present, I am using a Micca MB42X-C for this. Looking for an upgrade under 25k.
Any help and suggestion are much appreciated.
Below is my current setup:
Yamaha YHT-196(HTR-2064) AVR.
JBL Stage A170 Tower as the Front channel
Yamaha Satelite speakers as Surround. Sometimes I also use my Micca MB42x bookshelf as the surround too.
Room size: 11 x19 feet. Seating position: 8 to 10 feet away from speakers.
Thanks in advance for all your help. Cheers!!!
Elipson LCR is very nice. High sensitive at 92db. Easy to drive
Thanks ravindrads, but I am unable to find it anywhere, do you have any idea who is the dealer for it in India? Not sure but I think it will be out of my budget too.
Dear Bro.
Alfahat in chennai is the dealer. In fact he can suggest budget friendly other brands as well. I bet no one can match his price. I personally use Elipson LCR suggested by him for my HT setup. They are awesome.
You can get in touch with him on +91 98400 60332
Dear Bro.
Thanks ravindrads.. I will check it out
