renjith lal
Hi All,
I bought a new DAC (Hegel HD11) and its manual recommends to use coaxial or spdif input to DAC for best performance though DAC accepts optical and usb input.
My present 3Dplayer (blueray player Panasonic BDT220) has optical audio out and no coaxial out . I am using it for playing FLAC and cds. I was thinking of using a optical to spdif converter. Few forum members suggested that toslink or optical implementation will be very bad in blue ray players and adding a converter may increase Jitter .
I am looking for a solution, options are either buy a dedicated cd player from Marantz/NAD or CA and use coaxial/spdif out to dac, but I may not be able to play flac. Other option is getting Oppo 103 which can play flac and I assume it has a good coaxial implementation. But again Oppo is very expensive in India and my present blue ray player become waste.
Another option coming to my mind is buying a normal 2D blueray player
from Sony which has coaxial out and use it. Any idea how good coaxial implementation in these players?
So I am looking for a transport which plays cds and flac and don't need a good dac as I am planning to use standalone dac, not sure if there is one at a reasonable price. Please let me know if you guys have any suggestion.
Thanks in advance.
Renjith
Thanks in advance.
Renjith
