Mandatory glamour shots of the Denon DL103:
I had to drastically lower the tonearm height (from the height suited to the Kontrapunkt c) to get correct VTA for the 103. I probably need to lower it a half mm or so.
I'd like to revise my preliminary opinion of "sounds wonderful" of last night, to "sounds amazing", as it continues to amaze and dazzle me with its tricks. This cartridge is a midrange champion. What it omits (compared to much costlier cartridges) is probably that last bit of refinement and extension at the frequency extremes. It is hard not to like the mid range. Now I understand the hullabaloo surrounding this legendary cartridge is not for nothing.
Congrats on successfully setting up the cart. you mentioned that you need to lower the tonearm quite a lot to get correct VTA. What was the correct VTA? Is it the music you heard or you tried to level the arm when its playing record or you tried to match the angle as suggested in the specs. I have been struggling a lot to set up my rega bias 2 cart due to its low depth that's why I am curious. Does the Denon comes with a stylus guard?
