DENON Owners thread
I've done multiple firmware updates over the 2 years I've had the Denon, and it's up to date.
Haven't done the factory reset, but isn't there anything else I can try?
try another optical cable just to make sure. Then do the factory reset if its still not working then might be an issue with the avr.
Cheers.
I just bought a Sony 55X9000E and am super happy with the picture quality but I am struggling with the audio aspect. My receiver is a few years old Denon AVR 2113, and it does support ARC,DD, DD+, x9000e does support DD as well as DD+. however I cannot get DD+ to work over ARC. DD works fine over ARC but DD+ over ARC won't work . AVR shows DD+ on display but no sound from speakers.
https://www.sony.co.in/electronics/support/articles/00191214
I've tried numerous times to set up an aux output device like the Amazon Echo to my Denon X2200W using an Optical-Aux cable. Every time I end up giving up because I just cannot hear audio through my Denon receiver. I'm at my wit's end... Plz help. Here's a snapshot on my assigned inputs. I don't want to modify my HDMI 1 2 3 4 5. Rest everything I can tweak the way anyone suggests. View attachment 28967
I have x3400, i connected my stereo speakers with optical, no audio(realised optical is only for tv/cd input only), tried front LR preouts, still no audio. so concluded that if primary speakers(5.1)r connected, than it wont output to secondary speakers.
I also tried zone2 preouts, still no sound, when i tried playing music thru usb.
Any suggestions wd help.
I recently got Denon x3400 in Hyderabad. earlier had emotiva prepro setup, but changed that for Atmos. Have a 5.1.2 setup with in ceiling speakers, having configured audyssey multieq32, am quite happy with the amps performance.
Hi Guys, any good Denon service center in Mumbai. I have Denon x2100 US piece and its going into circuit protection mode. I have done factory reset still no use. Will never buy Denon products again. I had called profx but since its a US piece they will not service. any suggestions please.
I thought it would be helpful for you guys...the fault was the 100uf 200v capacitor... changed it and it costed about 100 rs
I have no brought from them...i believe a couple of FMs have......check with other dealers....the above link is indicative of the prices...
I suggest you try to get your AVR fixed first before shopping around. Of course if you have the money to invest, buy a solid and powerful power amp. Buy a basic pre amp and keep changing the pre amp as the tech evolves.
