Vivek Batra
Logitech Harmony Elite
This is the remote for 4500. While running Audyssey it asked if I want to pair the source. I selected yes and it asked me to press source (Blu-ray) and option till Dev tv and avr on top of the remote blinks. It said success but not workingWhat type of a remote is it? Programmable, punch code, or learning?
Sometimes despite pairing they do not work. My bitter experience. See if there is a remote leaning function mentioned in the manual.This is the remote for 4500. While running Audyssey it asked if I want to pair the source. I selected yes and it asked me to press source (Blu-ray) and option till Dev tv and avr on top of the remote blinks. It said success but not working
Knock knock any one?
No I was able to set it up and working fineTry it again. If not then probably the preset code on your remote does not COMPLETELY WORK for your particular Sony model player.
The next choice is probably a harmony remote. But I would just use the two remotes. But that is just me.
I went through the steps. Good find.Denon web manual has the preset codes available and I was able to set it up
Denon 4500
I sold my 2400 to a very close friend of mine and got the 4500 last week. I didn't go for grey. Got it from my regular dealer Max Home theater chennai. Grey it is sold at 95 and with bill and warranty 110000 so just 15k difference. Refer the link for my feedback on the avrWow man - when did you move from 2500 to 4500? How is the experience so far? Is it from the same known source?
Thank you Vinod... I too suspect the fuse might have blown up. Is that something that is visible right away if I open the AVR?Hello Mands,
It also could be something very simple. Since it is not completely turning on, it could be just a fuse blown on the power supply board. This could be due to a power surge or excess power which hit the AVR.
If you are handy, you could open up the AVR after disconnecting it completely from the power supply, disconnecting all speaker cables and connections and check the power supply. It could be just the fuse which has blown. Otherwise usually an AVR does completely stop working.
Also could be a cross connection in the speaker cables, can't say from here. You would have to trial and error it. Best of luck to you. Hope it works out.
Hi FM's,
My Denon 1911 AVR which is 8 years old is not switching ON. Did anyone else face such problems? Please suggest a service center or service advisor in Hyderabad where I can get it checked. I posted this in other threads as well. Please excuse me for that. Thanks in advance.
Vinod, Thank you so much.. I opened it and it is the fuse... It says 'T1.6AL250V' on one side and 'BUSS' followed by some symbols on other end.When you open the AVR, check where the main power plugs in to and which board. That is probably the primary power supply board. Now on this board, you should be able to find the glass fuses on this board. Now check these fuses to see if they have blown or not. If they have, you would have to replace the fuses to get the AVR hopefully working again.
Before you replace it, check to see if the wire inside this glass fuse is intact or not. If it has cut, then you will need to replace it and if the fuse is okay, then there is a problem somewhere else and you will have to show it to a service tech.Vinod, Thank you so much.. I opened it and it is the fuse... It says 'T1.6AL250V' on one side and 'BUSS' followed by some symbols on other end.
Can I but any fuse that says T 1.6 250V or do we have to go with original part? Please suggest.
Yes, the fuse is damaged... and its all burnt inside. Can I order it online or do I have to go to USK for getting one. I did not find the exact ones online but see something like T1.6 250V. Please suggest on how to get a new one.Before you replace it, check to see if the wire inside this glass fuse is intact or not. If it has cut, then you will need to replace it and if the fuse is okay, then there is a problem somewhere else and you will have to show it to a service tech.
