Hi, I'm using Denon X2600H for the past 2 months, I never had such issues. Its working fine.
I suggest you to go for X2600H which will keep you happy for the next 2-3 yrs without thinking of upgrading.
Thanks for the reply!
Not sorted,thx wd find out frm service center.Last week? So it’s all sorted now? I’m guessing it was the board itself because all of the ports are on the same board and the one on the front isn’t?
I guess your HDMI board got damaged and replacement may be required. You may get it checked in Kasi Electronics in Film Nagar, Jubillee hills. They are Denon authorized service center.Not sorted,thx wd find out frm service center.
Im also using a denon 2600..no issuesHi, I'm using Denon X2600H for the past 2 months, I never had such issues. Its working fine.
Please plan for proper ventilation as Denon AVR's tends to get warmer.Thanks for the reply!
Would also check with Solar electronics,ameerpet who i think is also hfv member. Have earlier used his service and was happy with it.I guess your HDMI board got damaged and replacement may be required. You may get it checked in Kasi Electronics in Film Nagar, Jubillee hills. They are Denon authorized service center.
Hey guys! I’m interested in purchasing the Denon X2400H or X2500H. Would really like your input/advice/warnings from the purchasers!
I am really skeptical because I usually hear negative stories about problems over problems. From boot loops to flashing black screens to overheating and random switch offs.
Would really like some help.
Thanks!
Recently received update on x1500h after updating I don't see 5ghz band before that it was working on 5ghz. Meanwhile I updated my router also from tplink c60 to tplink c80...... don't know if it's router problem or update issue.Does look like that.
Haven't faced since I did turn off control in AVR.
Now today suddenly 5Ghz band is not visible on the AVR, has anyone faced this
I have been using the Denon 2600 for sometime now and certain days they were on for more than 6 hours and no issues faced.Hey guys! I’m interested in purchasing the Denon X2400H or X2500H. Would really like your input/advice/warnings from the purchasers!
Thanks!
It's always better to purchase the latest model in a given series, in this case X2600H (2019) so that you will be in a supported environment. Denon usually supports a model for 3 years from the original release date. Also, X2600H supports HDMI 2.1 features.
of course they heat up but that’s no issue as far as you don’t suffocate them.
People have been advising the opposite for many years on forums like AVforum and AVS. They say never buy new because all the AVR’s will basically be the same with tiny feature updates. Rather buy one or two generations older for a great price. Unless it’s a feature you really really need NOW.
I won’t need HDMI 2.1 features for another 8 years cause I bought my non HDMI 2.1 TV very recently.
But thanks for the suggestion! I always appreciate it!
That’s what I like to hear.
Thanks!
X2600H is already a version behind (X2700H is the latest) and X2500H is two versions behind. One version is always fine and that's why I mentioned X2600H but two versions are a bit old in terms of supportability (considering their 3 years support cycle). For the older version, parts availability is always an issue with ProFx guys (authorized partner).
The 3 year support doesn’t inspire confidence
Problem is I wanted the X2600H but I can’t find it anywhere. ProFX says it’s discontinued and won’t support any warranty for it purchased anywhere else. HiFimart don’t have it either who are the only other authorized Denon dealers. Avstore has it but for 80k which is crazy!
That’s why I’m stuck with either the X2400H or X2500H. Maybe I should just stick it out until next year and see what happens in the market. I’m just worried about COVID price hikes!
GOD help me!![]()
Chech if X1600H is still available, it's nearly identical to X2600H.
GOD help me!![]()
From what I heard, import taxes / duties are gone up since CoVid and not much is coming in. Prices are increased. You can decide to wait it out or settle for a preowned AVR being sold over OLX or other platforms and make use till next year hopefully when things settle down....I would do that if I was you so that I dont miss out on enjoying music or movies playback....life is short....so make the best of it!
I think Ooberpad pad has it. Check it out.The 3 year support doesn’t inspire confidence
GOD help me!![]()
