Thank you so much for patiently answering all my queries.If the vertex that you are installing for your entire home has all the safety features then most probably your gears are safe. Stable voltage and low,high voltage cut off is sufficient for protection. Only doubt i have is if it will be enough for power surge or lightning.My case that's all i have and so far no issues for 6 years. Before i got the vertex i used a yamaha avr connected to an online ups with no voltage stabilizer and it worked without any issues for 3 years and then i hooked my denon 2400 to a v gaurd for a year and then my 4500 as well. Later on i realized v gaurd is not sufficient and i moved to vertex. My location isnt perfect and has frequent power cuts, Low/High voltage and lightning strikes and luckily i have not had any issues. But if you are very paranoid then you can invest in a product like Rontek which is a power conditioner with surge protection. It also has cut off features and individual circuit bank. Please continue the conversation in this thread which has few points covered regarding protection
Guidance with protecting my gears
Dear Fm’s I need your guidance with protecting my gears. So far I have connected my xtz sub directly to a belkin surge protector from the mains and my Denon avr, PA to vguard digi smart 200 and the blu ray player, shield, TV to a v guard crystal.Voltage is always stable at 230 and some times...www.hifivision.com
		 This is is my second Denon but first AVR.
