Ok, the die is cast. Just placed the order with diyaudiocart.
The TM design will use the
SM16IH-4 4-Ohm 6.5" midbass unit with the stamped steel frame, and the
TL26SG tweeter. I chose 4 Ohm for the midbass unit so that I can pull out more power from the amp for the large portion of the frequency range which the midbass will cover. Tweeters are more sensitive than midbass drivers most of the time anyway, and need to have their levels cut with L-pads quite often. So having a 8-Ohm tweeter with a 4-Ohm woofer will help bring down the relative level of the tweeter a bit. Driver cost for this model:
Rs.5,560/pair
The MTM will use the
M13NH-08 midbass unit and the
Tympany XT25SC90 tweeter. Here, the two midbass units will parallel to give me a nominal 4 Ohms per side, and will mate with the 4 Ohms of the ring radiator. Driver cost for this model:
Rs.8,571/pair
What can we guess about the final speakers going by just the driver choices?
- None of these midbass drivers are going to be particularly low-distortion, irrespective of what their sales pages say. In particular, I expect the 6.5" midbass driver to be just about average on that front. In comparison, the Dayton RS drivers would have had a lot lower distortion, but hey, we wanted Indian drivers. Of the two, I expect the 5.25" pair of the MTM design to give slightly lower distortion than the big single 6.5", simply because two 5.25" drivers have a larger radiating area, hence will have lower excursion. Of course, it's likely that many of us won't notice the higher distortion.
- The higher octaves, I expect, will be quite decent. Both tweeters are pretty good, probably roughly in the same league in terms of distortion. I expect to cross both designs over at about 2KHz or so.
- The bass response from both designs will be adequate for small rooms. (The typical Bombay bedroom is 10' x 13'. That's a small room.) The MTM may have lower bass extension than the 6.5" TM design, because of its smaller drivers and higher Fs. No earth-shaking home theatre thunder here, but may be perfectly adequate for most types of music. The MTM user who wants more bass can add a sub for the region below about 50-60Hz.
- I expect the midrange to be good, within the limits of any distortion issues in Point 1 above.
- These speakers will not be good party speakers -- they won't play clean and very loud. For those use-cases, you have to start with a minimum of 2 x 6.5" in an MTM config. But they should be good to excellent for relatively near-field listening in small rooms.
It'll be interesting to see how the whole thing turns out, when all is done and dusted.
By the way, I want to make one point explicit and clear:
I place no restrictions on anyone reproducing my designs for personal, commercial, business, or any other use, in any quantity. Kits and finished products made by others are most welcome. I just don't want anyone building and selling them commercially to say that they are based on my design. Basically, go do what you want with these designs, without asking my permission. But if you're doing it commercially, don't refer to me. Say you designed them yourself, or say you got the design from an unspecified source. All my speaker designs are in the public domain, unless otherwise specified.
The thing I find depressing about doing these designs is that I have
no visibility about how many drivers there are in stock of each of these models. If the designs turn out worth replicating, I don't know how many of you will be able to make them before the drivers run out. And with Peerless India, once a driver runs out, it will never reappear. We're the tail end of the remaindering surplus-disposal stream of a company which does not build these models any more.
In fact, diyaudiocart has more drivers listed with the "SOLD OUT" banner than drivers actually available, I think.
In fact, this was my primary reason to move entirely away from Indian drivers after the initial Asawari versions.
I bought the drivers for my Darbari in 2006-2007. Even today, I can buy a second set of those drivers. I like that.
Maybe someday, after this, I'll make one or two designs with drivers "imported and probably available in India".
