Hathway goes HD in Bangalore??
Hey....Got the box and its working fine. Though the picture quality is good but still i feel face contrast not matching. Possible that my be cable wire which is very good could be reason for the same. I am asking my cable operator to the change the same.
I am unable to auto fix the size of HD and non-hd channel with my tv. If HD is viewed with full screen then when i move to non-hd I am getting black bars in side...Is there any setting in SET Up box for the same ?
Go to settings and select the aspect ratio
Ten HD is blank for the past few days. Is it the same for others in Bangalore too?
The two "premium" HBO HD channels are now blocked and we probably need to subscribe to get them.
I am having pixellation issues in all HD channels and esp. more in Nat Geo set. Need to check with cable operator on signal quality at my home.
~Cheers!
I was told that there is some issue with the decoder of Ten HD. But I guess it is because of payment issues. I was told that the channel will be back in next 2 days(common reply).
Yesterday I was seeing pixellation in all the HD channels.
I tried with all the options available with my TV..Sony Bravia 330Ex32...But its not working :-(
Select Menu on STB remote --->Press red button -->Select System Setup--->Enter 0000 as the password--->Select Installation Setup--->TV Setup--->Select TV Type as HD, TV Size 16:9 and Fit to screen for On receiving 4:3 input video
Select 1080i resolution in HD Setup
Hi All.....Is there any problem with HD Channels? I am not getting any from last night. Is there any centralised customer care number.
Thanks,
Megharaj.
Had problem with the box and re-activated the box now. HD is on now. But still not getting sound for Movies Now HD (not sure whether its problem with my box orchennel problem) and also I dont get programme details majority of the times. Alway it will show "no information available" is it normal for other users as well ?
If you are not getting sound, try setting the sound format to PCM. Menu---Settings---User setup---Audio
About the EPG, it happens when the STB is started and becomes fine after some time.
Just a query guys. I was today quoted a price of 6500 for a hd box + hd channels for 1 yr. But the guy wasnt sure if 6500 includes pricing for sd channels as well.
How much are you guys paying/paid for hd box + hd channels + sd channels for 1 yr.
I am from mumbai
As far as I know the HD box costs Rs 2500(just the box without any HD/SD channel subscription). HD channel for one year is Rs2200. SD channel cost varies depending on the area and in DAS areas it depends on the package that they have subscribed to.
Guys those who are using Hathway HD, how's the picture quality? Is it comparable with DTH operators like AirTel or Tata Sky?
