Hifi Wood Rack - Group Initiative - SoundFoundations (ali)
polish team
the rack on the far side is complete
the other ones are being sanded and wax filled / first coat
polish team
Super Magma ! :licklips:
I like what I see - in the pic at least.
Great 'fit & finish' !
You should sell these with the Cera Compact - 4 pieces [that need to be installed below the rack] - I am sure that the rack's performance will improve.
You have any more pics ? Close up on the wood & the grain - after it was polished & ready to ship..
post no 125 shows the grain and color of the shelves
howvere ignore the column color in post 125
the newer column color is what you see in the pic above
its the natural teak finish on BTC
Sir,
I saw those;
Post # 125 i.e.
But the ones above are 'better'
They look well finished & the BTC Sides looks much better.
I did not like the black sides.
Also the Polish on the shelves I liked.
I just hope your prospective clients buy the Cera Compact to place below these racks;;;
yep
the new lot was polished much better
i had an an enitre team for this lot - since it needed a lot of work
sanding waxing and matching
and yes the BTC grains are much better
what surprises me is how you noticed the differnce though my pics are at a far angle
Since bhagwan ji mentioned, i also zoomed in the pics and found the texture of new columns better then the older rack
Actully due to the dark color of the older columns, the texture is not visible
My new rack :)
The earlier rack had some issues and most important was that my power amp was not fitting. I and Ali both had forgotten to check the size
I had asked ali to repair it but ali was gracious enough to build an all new one for me
The colours in the pictures look very dull then what the rack is in real. tried my best but this was max I could manage from my phone cam
It is indeed solidly built
