High Current Amplifier
Higher the power, lesser the chances of the amplifier to hit clipping when extended low frequency music signals are being fed to loudspeakers. One more thing high power amplifiers operate at high voltage rails therefore the slewrate is very high giving very fast attack and decay times which further makes the transient response very much lively.
Thank you Kanwar for sharing this knowledgable information. I presently have Marantz PM6100SA & SM6100SA, which is a Biamp model. The high frequencies of my Wharfedale Denton 80th Anniversary LE are driven by PM6100SA and the low frequencies by SM6100SA, what I obtain is punchy sound. Now what philosphy does this biamp Vs Pre- power work on?
Thank you for your time.
The test of the machine is the satisfaction it gives you.
There isn't any other test.
If the machine produces tranquility, it's right.
If it disturbs you, it's wrong
UNTIL, either the machine
OR
your mind is changed.
I think you've also learnt the above through experience.;)
Dear Kanwar
Thank you for your patience and endurance in answering all our questions. I understand most of the data in empirical terms, but using it in the real world has often eluded me. For example the use of the voltage data seems useful to determine potential clipping but I not quite sure how .......
Max output voltage is 48VRMS @ 4ohms or 134 V Peak to Peak and 41VRMS @ 2ohms or 116 V Peak to Peak
I was also not sure what the benefit (or dangers) of designing without capacitors in the audio path (direct DC coupling) of an audio amplifier may have. Sorry if that is quite a basic EE question.
By the way, I have occasionally used these notes (see link below) to understand some of the issues to do with amplifier output ratings. Do you think it is accurate in most part and perhaps it would be useful for some FM readers:
Undertanding Power Amplifier Power Ratings
Hey Kanwar,
Will AVRs work with pro speakers ? Are there any technical problems apart from using the right connectors ? Most of these speakers seem to be 8 ohms.
In our office ( we work in the computer games industry ) we have a situation wherein we need to get portable and rugged speakers to use with a game-demo system.
It is a 2 channel system but we are forced to use AVRs because all the gear is connected via hdmi to the amp. BTW : Are there two channel amps with hdmi ins ?
The only scientific reasoning behind bi-amping is that it gives isolation from interaction of back emf of both HF and LF drivers with each other and associated passive crossovers. This way the LF driving amp doesn't have to cope with back emf arising from the HF driver+HF passive XO and vice-versa, which improves the cone control aka damping factor hence punchy sound.
Though having an active-xo and zero passive xo in path results in much better resolution than passive bi-amping.
Hey Kanwar,
Pro speakers are much easier to drive than low sensitivity home speakers, no issues in driving them thru AVR's. Haven't see any pro-amp with HDMI input, can't say about home audio amps.:)
@ kanwar, with all the questions pouring in, it seems you have become the ONE to penetrate all the DARK MAGIC that wanders around HiFi world and reveal the TRUTH.
My request to you will be to be with us and take the pain & time to explain, coz we need guys like you in this forum who speaks technically and are not biased.
One more question from my side: When will be the "kanwar" made home amp available in public? Remotely possible in 2013?
Thanxz:)
Work in progress, fingers crossed.;)
Dear Kanwar
Its simple, when the peak voltage limit is reached, it cannot exceed power supply rail voltage level which is the ceiling for the clipping.
Imagine yourself floating inside a room and your body is suspended just midway between height of the room, now your clipping level would be when your head touches the ceiling or your feet touch the floor.
Designing without capacitors ensure zero phaseshift [capacitors cause 90deg phase shift under certain conditions] along with more transparency and you don't have to listen to the artifacts introduced by capacitors. Electrolytic capacitors are worst in this regard, best are film capacitors. Another reason is aging process which degrades the capacitors over time. DC coupling is harmful for speakers if the amplifier is not protected by DC fault protection, other wise dc offset from poor source transfers to dc coupled amp and might fry the speakers by passing dc component at output.
Nice article:)
Replied in true blue
Thanks Kanwar. Much appreciated.
Thnking of picking up a pair of any of these :)
Peavey PR10 NEO 10Inch 400 Watt 2Way Speaker
OR
JBL AC18/95 8 2-way Passive Compact PA Speaker
OR
Yamaha A10 10 2-Way Loudspeaker
