How to play mkv file on Sony Bravia LED tv-a guide
here is the media info of original mkv file with dual audio that shows error in tsmuxer
General
Unique ID : 171163028757997988029568225172291188393 (0x80C4CCDCE7084477AC0BA204CFADF6A9)
Complete name : D:\hollywood\The Avengers 2012 3D 1080p HSBS Dual Audio (Hindi_5.1-English_5.1) V.K{HKRG}\The Avengers.mkv
Format : Matroska
Format version : Version 2
File size : 2.49 GiB
Duration : 2h 22mn
Overall bit rate : 2 491 Kbps
Movie name : V.K{HKRG}
Encoded date : UTC 2008-01-05 13:07:37
Writing application : mkvmerge v5.5.0 ('Healer') built on Apr 6 2012 21:43:24
Writing library : libebml v1.2.3 + libmatroska v1.3.0
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : [email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Muxing mode : Header stripping
Codec ID : V_MPEG4/ISO/AVC
Duration : 2h 22mn
Nominal bit rate : 2 203 Kbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.044
Title : The Avengers 2012 3D 1080p HSBS V.K{HKRG}
Writing library : x264 core 125 r2200 999b753
Encoding settings : cabac=1 / ref=4 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=2203 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Default : Yes
Forced : No
Audio #1
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : A_AAC
Duration : 2h 22mn
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Compression mode : Lossy
Title : V.K{HKRG}_English_5.1
Language : English
Default : No
Forced : No
Audio #2
Format : AAC
Format profile : LC
Codec ID : A_AAC
Duration : 2h 22mn
Delay relative to video : 9ms
Title : V.K{HKRG}_ Hindi_5.1
Language : Hindi
Default : Yes
Forced : No
Issue is due to this.
You can't remove header stripping muxing from tsmuxer. You need to install mkvmerge gui..which is a freeware. Open it and go to File-->options--->mmg....there is a checkbox saying "disable header removal compression"..check that box and click on ok.
Restart mkvmerge gui.
Add the file-->mux it-->will produce a new mkv file--->add it in tsmuxer as mentioned in first post-->mux and play.
but how can i change it to the hindi language as it is in dual audio (hindi/english)? can mkvmerge do that also. can you also provide the link for download mkvmerge
When muxing in mkvmerge for the first time you will see two audio stream. Uncheck the first audio which is in english..but make sure the second audio is checked.
After adding to mkvmerge stream would appear like this-
1.V_MPEG4/ISO/AVC-->video stream..check it.
2.A_AAC-->click on it then see below in general track option language..if it's english uncheck it.
3.A_AAC-->click on it then see below in general track option language..if it's hindi make sure you have checked it.
Now mux..only hindi audio will appear now.
hi thanks dude, u made my day, each and every information was really helpfull to me and worked perfect. i used several software to convert the file but only u saved my hard disk. really thank you very much.
only one more thing not from the topic but can you also provide me any 3d converter software to convert my 2d movies in 3d sbs (torrent file). thank you once again and keep replying to this usefull thread.
Thanks Sir,,,
Nandan
I am noticing that people are complaining about bravia led not playing mkv files. So here is a guide on how to play them.
1.Download tsmuxer GUI..it's a freeware.
2.Add the mkv file u want to play.
3.if u select the video track there is an option change level..if it is greater than 4.1 change it to 4.1.
4.now in output select m2ts muxing and point the output to a destination folder and click on start muxing.
You can playback the output file from your usb drive on bravia.
So don't just buy a tv on the basis of playing mkv files..choose tv with best pq and most important what you like.
It will take about 2 min if u are muxing 2 gb file..and so on.
Bravia can read exFAT(where file size support is unlimited),fat32,fat16(file size support 4 gb, disc size support 32 gb).
Pls post if you are having any problem with playback.
mkv is a container and m2ts is also a container. This application only change the container.. doesn't reencode the video..so there is no huge cpu requirement.
Buy a Sony bd player, it plays mkv.. Better route than encoding with different codec which takes lots of hardware power, time and effort.
Sent from my GT-I9100G using Tapatalk 2
:thumbup: Thumbs up
Just giving an option....
for those who can actually buy BD player, but not doing so by thinking about saving money and do encoding by spending time and effort.
And BD player does not cost a fortune nowadays... :)
:thumbup: Thumbs up
I've PS3 already which is also a BD player, so what suggestion for me...
hi bro i have problem regarding audio there is audiowhen i convert file with mkvmerge, but when i use tsmuxer the auio is gone i am providing the media info of two file.
can u please see what is wrong with the second file which has no audio play back .
1.with audio(mkvmerge)
General
Unique ID : 227438736523885775710045130263850342406 (0xAB1B1B79399281139B545BB324235806)
Complete name : D:\hollywood\Transformers Dark Of The Moon 2011 3D HSBS Dual Audio (Hindi-Eng) --SSR-- (1).mkv
Format : Matroska
File size : 2.16 GiB
Duration : 2h 34mn
Overall bit rate mode : Variable
Overall bit rate : 2 003 Kbps
Movie name : Transformers.Dark Of The Moon.2011.BRrip Eng-Hindi[~HFR~]
Encoded date : UTC 2012-11-28 10:54:36
Writing application : mkvmerge v5.8.0 ('No Sleep / Pillow') built on Sep 2 2012 15:37:04
Video
Format : AVC
Format settings, ReFrames : 5 frames
Duration : 2h 34mn
Bit rate mode : Variable
Bit rate : 1 938 Kbps
Maximum bit rate : 25.0 Mbps
Height : 800 pixels
Display aspect ratio : 2.40:1
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.053
Stream size : 2.05 GiB (95%)
Writing library : x264 core 120 r2120 0c7dab9
Encoding settings : cabac=1 / ref=5 / deblock=1:-1:-1 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=8 / b_pyramid=0 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=2pass / mbtree=1 / bitrate=1938 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=25000 / vbv_bufsize=25000 / nal_hrd=vbr / ip_ratio=1.40 / aq=1:1.00
Default : Yes
Forced : No
Audio
Format : MPEG Audio
Format profile : Layer 3
Mode : Joint stereo
Mode extension : MS Stereo
Codec ID : A_MPEG/L3
Codec ID/Hint : MP3
Duration : 2h 34mn
Bit rate mode : Constant
Bit rate : 64.0 Kbps
Channel(s) : 2 channels
Sampling rate : 22.05 KHz
Delay relative to video : 2s 0ms
Stream size : 70.7 MiB (3%)
Title : [~HFR~]
Writing library : LAME3.98.2
Language : Hindi
Default : No
Forced : No
Menu
00:00:00.000 : en:(01)00:00:00:000
00:08:52.573 : en:(02)00:08:52:573
00:14:26.615 : en:(03)00:14:26:615
00:20:20.928 : en:(04)00:20:20:928
00:28:48.143 : en:(05)00:28:48:143
00:36:18.634 : en:(06)00:36:18:634
00:45:18.549 : en:(07)00:45:18:549
00:51:53.026 : en:(08)00:51:53:026
00:56:34.224 : en:(09)00:56:34:224
01:04:13.307 : en:(10)01:04:13:307
01:12:56.705 : en:(11)01:12:56:705
01:19:09.077 : en:(12)01:19:09:077
01:23:41.391 : en:(13)01:23:41:391
01:28:44.819 : en:(14)01:28:44:819
01:35:13.082 : en:(15)01:35:13:082
01:42:44.158 : en:(16)01:42:44:158
01:49:12.337 : en:(17)01:49:12:337
01:56:42.912 : en:(18)01:56:42:912
02:04:59.116 : en:(19)02:04:59:116
02:11:29.590 : en:(20)02:11:29:590
02:19:10.884 : en:(21)02:19:10:884
02:25:37.520 : en:(22)02:25:37:520
02:34:23.337 : en:(23)02:34:23:337
2 file with no audio (tsmuxer)
General
Complete name : D:\hollywood\Transformers Dark Of The Moon 2011 3D HSBS Dual Audio (Hindi-Eng) --SSR-- (1).m2ts
Format : BDAV
Format/Info : Blu-ray Video
File size : 2.39 GiB
Duration : 5h 8mn
Overall bit rate : 1 110 Kbps
Maximum Overall bit rate : 35.5 Mbps
Video
Menu ID : 1 (0x1)
Format : AVC
Codec ID : 27
Duration : 5h 8mn
Bit rate : 994 Kbps
Nominal bit rate : 1 938 Kbps
Height : 800 pixels
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.027
Stream size : 2.14 GiB (89%)
Audio
Menu ID : 1 (0x1)
Format : MPEG Audio
Mode : Joint stereo
Codec ID : 4
Duration : 5h 8mn
Stream size : 141 MiB (6%)
The audio codec of mkv file is mp3...and it's not supported in m2ts container.
Please do this instead--
u need to convert mp3 track to dolby digital track.
Here is a good app to do that...
Code:
http://www.mediafire.com/?c6ky6wglh0n930z
http://www.mediafire.com/?gnn2ncqtwseqxhf
These are hd stream extractor and dolby digital encoder. Download and extract both of them in a folder..then click on HdBrStreamExtractor.exe and add your mkv file. Then click on features and u can see all the tracks i.e avc video track and mp3 audio track.
Now just check only the mp3 audio track and from dropdown list of extract as select AC3...and then click on extract.
Your dolby digital audio will be extracted in destination folder.
Now just follow the instruction in the first post..just add your dolby file which has an extension .ac3 and uncheck the mpeg-audio/mp3 audio in tsmuxer. After muxing it will be playable in bravia.
