Integrated class A amp query.
technophobe
Uk
Hi all I have just purchased the 90s technics SU X502 amp with matching speakers. Having read various articles I'm under the impression that class A amps are designed to get warm and can handle it. When I'm playing mine after about 5 mins whatever the volume it does start to get warm, but I'd say it's very warm, not hot. What should I do about this, if anything?
Secondly, being an old amp (that still fetches a price by the way)I want to make sure that I prolong its life as long as possible so are there any simple things I can do? I've thought of using a small fan and directing it onto the vent, or taking the back cover off and removing dust, could these be reasons for amp getting too warm?
Your amp is not a class A amp. Or at least it is more closely related to its Class AB brethren than class A ones. Give it sufficient ventilation, but don't worry too much.
My late 80's Luxman M06a class A starts running quite warm in about 15 min. By the end of an hour the top plate is quite hot touch. I ensure enough ventilation around it. Never had issues or shutting down even after a couple hours. This would be it's first summer with me lets see.
BTW it starts to sound so much more wonderful as it gets hotter.
