LG 2016 OLED Owner's Discussion
New Firmware released please update if you haven't
3. Release History
[03.60.09]
1. respond to 2017 HDR standard (HDR10 / HLG)
2. Work around M16+ Dolby HDR and handle scenario restriction issue
3. respond to DA Full feature (OLED Model)
4. additional response to 2017 CP Hot Key requirement
5. improving CRP performance(adding Reset feature by In-Stop )
[03.60.15]
1. To improve T8 store stream equipment issue.
3. Release History
[03.60.09]
[03.60.15]
Those are the old firmware logs.
New firmware is 4.70.06
Got the update for UJ752T. I don't c the new Technicolor HDR mode.
Looks like there is some improvements with HDR but Youtube HDR is screwed after the new update videos look bad compared to previous update.
Yep my bad pasted old firmware notes. Technicolor HDR mode will be displayed when the Tv detects that content is being played.
Technicolor HDR & SDR picture mode is supported only on 2017 OLED & SJ series led tv. It's a preset just like isf expert modes.
off course at first it will be only limited to higher end models. I am optimistic that in time UJ 2017 series will also get it. HLG is already listed
It won't Technicolor needs 10bit panel. UJ752 is not. I will repeat it again it's a picture mode just like ISF EXPERT MODES. Nothing related to HLG or DolbyVision.
I am confused now. Netflix Test Pattern says that its 10bit. The 10bit line does not have any banding at all it's smooth.
Also while watching a video on netflix app how to see at what resolution and bitrate its playing like it shows in test pattern video
After almost two months I landed home yesterday to find my first glitch with the B6. It has been operating on internal speakers as my daughter finds that more convenient. But now when I try to go back to ARC, it keeps going back to internal speakers unless I deselect SIMPLEX. Any reason why this should be happening?
have you updated to the latest firmware. some audio issues were ironed out with this
I had the same problem with soundbar. Switched off the TV and soundbar. Removed the cable from soundbar HDMI ARC. Plugged it back and enabled sound through HDMI ARC. Had to try it a few times to get it working. Faced this issue just once.
Its on auto update. Hence updated. 5.0.something.
Thank you. Let me try that once I get my energy back.:)
Understand from some blog that LG OLED does not pass 5.1 CH via ARC. Is this true? When I just tried ARC on my E6 connected to Sony Dav Dz340k, audio never went to 5.1 and was not good. Infact when its connected via audio out using a stereo cable its much better compared to ARC. Whats wrong with my setup? Or like I said in my first statement "LG OLED has issues passing 5.1 via ARC"?
The Indian sets don't support auto update, you have to manually install the latest firmware by usb. Get the latest firmware which released i think this month from lg india site. I am on 5.30.10 firmware on my B6 which is the latest.
Cheers.
Cheers.
I think they do. Mine just auto updated 5 mins before you posted. It's now on 5.30.10.
wow, ok so you got lucky, read about many other FM here that auto update doesn't work on their B6. Anyways as long as the update happened :-)
Guys,
Anyone here with a 55" Oled has increased their warranty? i got 1+1 year warranty & planning to increase it. We need to call the service center or the dealer for the info?
Cheers.
