Need suggestion denon x4500h vs denon x3700h
I was also in a similar dilemma and went with X4500 mainly because of Auro 3D.
I’m using it with projector and 8K is not really important for me.
So, if 8K and HDMI 2.1 features are important for you then go with the newer models, else go with X4500. It a steal for 75k
Is it 4k projector. Do you have any issues with 4k movies as it has 4k/60hz compatibility compared to 4k/120hz of 3700
So, if 8K and HDMI 2.1 features are important for you then go with the newer models, else go with X4500. It a steal for 75k.
I'm not interested in 8k. Anyway iam not into gaming also.
I don't get warranty . As it was bought from usa but unused.
US equipment usually works on 110v AC, so you will need a step-down transformer to use it here. Also, the board no of the US AVR is different from what Denon ships in India. That said, ProFx might not be able to source those boards for you in case of any issues. I am not trying to scare you off; just listing out the Pros n Cons.
That's a different equation altogether. I was thinking it was a demo piece sold with warranty. Without warranty it is a risk. You must be prepared for 60k minimum if a board goes kaput. But then you save that much already. So you can't lose much. I changed my mind. It is worth the pick.
