sharadgaur
Hi John, the location of the door is probably the only thing which will affect the room acoustically. Try to locate the door away from reflection points, preferably on the sidewall and behind the listening position. A heavy door will ensure that it does not rattle at loud heavy bass music. Avoid windows if you can help it. I would suggest you go to realtraps.com and read the articles on acoustic treatment. Cheers.
