cmsajith
In my experience IS really helps only for zoom lens.  Anyways, its your call sam.
Sorry for OT
			Sorry for OT
Sorry for OT
Before getting the dslr, I wanted to buy a compact that I can carry around easily, in my pocket. Did not want superzoom.
I was STRONGLY advised by my "network" to go for a DSLR and I went for it. And I love it.
However, I STILL want to buy a camera which may not have superzoom, but fits my pocket easily and is easier to carry around. Maybe a mobile with exceptional camera will do the trick. But I want a large sensor size, good ISO capability, big aperture.
Fuji X100 is nice, but EXPENSIVE.
If I am getting or can get 550D for the same price point as A35, or D3100, then its should be the one to go for..... right.
You can't go wrong with a well established camera like the 550D. My humble opinion - you can consider the following strategy:
Remember you are building a system and not just buying a camera. So consider it similar to assembling an audio system consisting of "separates". It sounds like you like the 550D and you cannot go wrong with this choice.
Buy the most robust and well built DSLR you can afford which also has the features you really like. Over a long term, build quality will also become as important as features. So it is also important to buy a camera that will withstand the test of time - our handling will invariably tend to become more casual and "slam-bam" over time. Start off with a 1.8 50mm prime lens and avoid buying the kit lens. In fact, I would say that carry only this lens with you in your trip. Firstly, this will be the most compact combo to carry. Secondly, you will quickly figure out the advantages and the limitations of the prime lens. Thirdly, worst case, if you find yourself seriously hobbled by the limitations of the prime lens (such as the lack of zoom), you can always buy a zoom lens while you are traveling.
The thought process that I took was slightly different - I deliberately bought the cheapest DSLR I could find because I thought that if I find myself not using the camera much, I haven't wasted too much money to begin with, and if I end up becoming a photography nut, I will want to upgrade my camera in a few years anyway so it really doesn't matter what body I initially buy. Plus, upgrading later on will be much cheaper as I will be able to continue using all the lenses I would have bought in the meantime. I guess it is the equivalent of buying a pair of good speakers with a cheaper amp and then upgrading the amp.
^^ One thing I missed noticing (my bad) was that with 550D it says image ratio 3:2!!!! I dont want my images to be 3:2. I will always view my snaps on my 1080p 16:9 ratio LCD or monitor ...... and with 3:2, I will have those irritating black bars ...!! I hate those black bars ...... now this would a serious deal breaker .... damm when finally I stuck to one choice I have this ........ gurus kindly shed some light .....
Ok I think by screen you mean the View finder screen of the camera, that now has a 3:2 ratio to match the native shape of the sensor.... right..... I am pretty sure that is some advantage over other models. But I am talking about the LCD screen where I am gonna view the images, which has a native resolution of 1080p 16:9 (all does), I will have those black bars on the right and left side of the image (though still narrow in width as with a 4:3 image) but they will be there right ..... that is something which would ruin the slide show on the LCD. I dont know why they have not included a 16:9 image resolution when it pretty evident and common that most of the displays (infact 99.9%) now have a native 16:9 ratio resolution (1080p) .....
Sam
All SLR sensors come in 3:2 native format. My P&S has a button for 4:3 3:2 and 16:9 format. If the DSLR has 720p or 1080p video recording, then it should be in 16:9
HTH
--G0bble
