I am not getting sound through the centre speaker.. Any idea which setting cud be wrong ? I even tried Level Cal in setup option .. The sound was coming through all speakers but not through centre speaker
please check the wire connection at both receiver and in Speaker.I had the same problem in rear left speaker.However, just pull the wire out from the speaker connection and connect it back.Check that you are not pushing the wire too hard inside the speaker.It should be connected with the copper of the wire to the speaker metallic connection.
For my case I pushed it hard and the plastic coating of the wire actually connected to the metal connector off the speaker which caused issue.
I got it yohoo... bill will be sent today. I will suggest EMI option with 23700, as price wise not much difference, but one can pay in 3 EMIs without loading monthly budgets (unless its a small expense for you) hyeah:
I am new to this but i doubt that the person teez is actually a self promoter.
After going through onkyo 3400 ebay listing and after checking the id history of that person, i came to a conclusion that something is missing in here.
Hi there're..I bought mine from Reliance Digital GGN .. Free installation worth INR 800 and Demo by an Onkyo specialist. The price @ Reliance is a little higher though at INR 27000 but you can always bargain for freebies like HDMI & Optical cables.
