sachu888
This is good news Sachin. Any idea when you will be receiving the parts?
20 days (approx).I may be able to ship B1 kits early Jan 2013.
Sachin
How's this for a 5 channel source selector? Eagle files available, of course.
Got some good inputs from Om and Sachin, and we are nearly done with the design of
the source selector board. Hope Sachin can help us with group buy if there is interest.
It looks like this now.
Hi Sachin, cost is for the kit or the pcb?approx cost should be Rs600-800
I'm in for a kit too. BTW, how do we power this thingy?
Capt, it has 2 ways to power it -
1) Regulated 12V source available in the chassis - use the connector on left side of PCB.
Do not install the voltage regulator.
2) Input voltage is more than 12V - use the connector on right side. Install the
7812 voltage regulator chip, with a heatsink if needed.
Resistor values etc are designed for 12V supply and relays.
But the board can be used with other voltages like 5V or 6V also, provided
you use the appropriate relay, and install the appropriate resistors.
Hi Mishraji/Sachin,
I would appreciate your help in integrating Pass b1 with CNC and SSP by helping me out with the connection circuit diagram in the attached picture. It will be of great help for the other newbies like me.
Santosh
Source Selector GB
Sann - 1 kit
Quad - 1 kit + PCB
keith_correa - 3 kit
captrajesh - 1 kit
apk - 1 kit
rohitmusic - 1 kit
TheCoolestOne - 1 kit
+1 kit for me
