IMO this is a pretty good recommendation for ANY audio enthusiast within a budget unless he/she has figured out what speakers/amps they really want (only for stereo not HT). Go active, add sub later. You will get a lot of features, less clutter, no need of a preamp if you use PC/phone/streamer as a source, you will an efficient amp built in (with good DSP), need not spend on interconnects/cables, and ultimately save a lot of money. You can upgrade DAC easily if required. I would buy a 2.0 active setup if i were you right now (actually if i were me and had the budget to be honest).
Good luck!
EDIT:
JBL Actives have great reviews (also check youtube review, might be little biased though):
https://www.amazon.in/JBL-Professio...hild=1&keywords=jbl+lsr&qid=1628018611&sr=8-9
https://www.amazon.in/JBL-306P-Powe...hild=1&keywords=jbl+lsr&qid=1628018611&sr=8-5
Some models from Edifier, Kali and Adam powered monitors might be within your budget if you can source in your city or from abroad.
