Finally, after 3+ years found a good Upgrade to my DAC Denafrips Terminator V1.
No Surprises here, Upgraded to Denafrips Terminator V2 12th Anniversary Edition 😉.
All the traits of V1 but just better in many ways, though the difference in pricing may not justify the incremental upgrade but I'm quite happy with it...
Bought Mission QX2 MK II, My first Hi-Fi seperate component. Loads of Bass, Forward vocals, Laid Back and very Warm sound - Low frequencies overshadow all other frequencies except for vocal [Frequency below 77hz most prominent at all listening levels i.e. whispering sound level to high decibel]. Mid Bass is present and but not thumping. Highs are there but not simmering, somewhat restricted and sub-dued.
lol, set it up away from a wall to reduce bass reinforcement.
Set up 1 feet and them 2 feet between wall and rear of speakers, din,t make much difference. Tweeter sounds restricted, as if its vocal chords get choked mid way (in songs where highs decay slowly e.g most of Shreya Ghoshal, it stops abruptly midway. It has almost 20hrs burn in, will twitter performance improve on further burn in?
That I believe only Elon Musk can answer. Unlike woofers, tweeters don't move enough to cause changes in the elasticity of the tweeter cone material. So there won't be drastic change and Shreya Goshal will almost sound the same as now.
Very interesting
Just went through the webpage
It uses dsp to regulate voltage so noise free and hopefully reacts absolutely quickly
After several months of search I finally upgraded my amp to SoulNote A1, this is my first Class A/B amp, I had a peachtree NOVA which is a Class D amp but it has stopped working few months back and couldn't service it. The SoulNote was way beyond my initial budget but I had stretched to go for it after listening to several other amps over the last few months. I haven't set it up completely yet as I am looking to add a power stabilizer before I start using the amp regularly.
