thomasalex
Rex i have adjusted my amount with vivek. He has to send me. Pls check out with ranga whether he has wired ur money
I would like to know if any of our guys who paid 10k got their balance amount because I didnt
Neo 49 , not to worry, you have made a good choice. I have been using the POHD extensively for a week now and I find it quite ok. It plays all formats ( from 1080p mkv's to Flac"s ) really well. It's internet radio function is great . I can also stream files from my laptop over wifi without any problems.
It does have a very plain looking interface , but how long are you going to be looking at the menu ? I understand there's a issue with HD audio ( some formats only ) but since i use stereo , I do not face any problems.
I think the guys who complain are nitpicking. Most media streamers have their share of problems( xtreamer has a lot of complaints ,too !)
The ac Ryan team is working on firmware upgrades and I'm sure things will work out.
DOLBY True HD issue solved?
Anyone tested? How about DTS HD-MA?
I am also intersted about it's Torrent capability.
1. Is it comparable to downloading via PC?
2. Can I schedule Torrent Downloads? ( I can only d/l bet'n 0200-0800 Hrs).
Hi Guys update from ranga regarding HD audio
Please inform members of ur group buy that the current version of the firmware in AC Ryan has a bug .
Due to a current bug in this firmware version, user may need to set to HDMI 1080p 50Hz in order to pass-through HD audio correctly
Thanks & Regards
