Rare gramophones-radiograms-records
Also, have a look at the Photo in the LP titled "Intimate moments with Yesudas" Hindi Film songs.
Yes there is only one Vinyl of Hindi film songs of lovely voice of Yesudas. Good compilation but if I remember is with little echo added. But very listenable.
Anilkumar, check this ebay selling you will like it. :)
McIntosh Marantz JBL Altec Jensen Western Electric Fisher Scott EV Equipment | eBay
Check the pics below the listing. Tannoys, JBL, Western Electric, Mcintosh, Dynaco etc. Good Stuff. Would work for free in this shop.
Hiten,
Thanks for the link. My heart got filled.
It is not the only LP, I could already collect 2 45 RPM LPs and 1 33 RPM LP of Yesudas with Hindi film songs .
Anil
It is not the only LP, I could already collect 2 45 RPM LPs and 1 33 RPM LP of Yesudas with Hindi film songs.
Which are the other two Yesudas LPs ? I keep atleast one vinyl of every artist, music director and Indian classical singer. So if there are other Yesudas album with songs I like, I definately want one.
Thanks and regards.
dear mr. Anil
could you list yesudoss's hindi lps.. Please.........
srinivas
45 rpm - film compilations
1. Intimate moments with yesudas hmv 45nlp 1025 mono
2. More hits yesudas hmv 45nlp 1153 mono
also if possible get the following film lps
1. Hindi film naiyya - hmv 45 nlp 1093 mono
2. Chintamanee surdass - t series sflp 1036 stereo
My new addition SONY PS F9 Portable- a direct drive turntable with a linear tracking tonearm and quartz locked turntable motor.
Built-in equalizer and amplifier allows two pairs of headphones to be used, there is also an equalized line-level output for use with an external amplifier or tape recorder.
A built in brush to clean the records too.
I need to put the three 78's on cd, I do not have 78 speed, the only option is to increase the pitch or find someone with 78 rpm TT.
The records are
1. Sara Sita - Ram Gopal Orchestra
2. Dance Allaripti
3.Sadhana Bosas Dance
Hope I got the names right, these were used by my neighbour to learn Bharatnatyam.
The records are
2. Dance Allaripti
This can be done through Audacity. Read here, lower speed dubbing
Recording 78rpm records - Audacity Manual
I use Soundforge, but I need a 78 rpm TT or I can increase the TT speed pitch but this will damage my cartridge.
Tks
Other Portable TTs already in my possession
1. SONY PS Q7 with brand new needle.- Runs in Mains.
Platter: 78mm aluminium alloy diecast
Motor: linear brushless and slotless motor
Drive system: direct drive
Control system: magnedisc servo control
Speeds: 33 and 45rpm
Wow and flutter: 0.08% WRMS
Signal to noise ratio: 68dB
Automatic system: lead in, return, reject
Tonearm: dynamic balanced low mass type
Dimensions: 215 x 235 x 58mm
Weight: 2.5kg
2. AUDIO TECHNICA SOUND BURGER- Runs in Battery and DC
Platter: 90mm aluminium die cast
Motor: electronically controlled dc motor
Drive system: belt drive
Wow and flutter: less than 0.2%
Signal to noise ratio: 50dB
Tonearm: dynamically balanced type
Cartridge: dual magnet type
Tracking force: 2.0g
Output voltage: 4.5mV
Stylus: ATN-103
Amplifier section: 30 to 25,000Hz, 110mV (line out)
Dimensions: 290 x 99 x 65mm
Weight: 1.2kg (not including batteries)
Hi friends, i am very happy to share my new list with you.
I have collected few LP records today.
Finally got Saajan (Nadeem-Shravan) LP after long hunt.
And also got "Ishq Par Zor Nahin" (S.D. Burman).
Do Raste
Mera gaon mera desh
Aon milo sajna
App aye Bahaar ayee
Chor machaye shor
Prem tapasya
Kaaliya
Dharam veer
Anjaana
Mehboob ki mehndi
Arzoo
Alibaba aur 40 Chor
Be-imaan
Kaamchor
Sanjog
Tarana
Saajan
Ishq Par Zor nahin
Dard
Few tools our GrandPas used
1. STYLOUVE -Stylus tip viewer
2. BI-SONAR Phonograph pickup-Electric Pick-ups/Soundbox for Shellac 78 rpm Records/Gramophone
3. Grandpa's mini spool tape system
4. Is it a shellac Rec cleaner
My new addition:
DUAL CS 617Q ULM Series turntable with Ortofon Dual TKS-55E cartridge.
Specifications: An all-metal unit but looks like plastic. Two Speed (33.33 & 45 RPM), Strobe Light,Front Panel Controls,Single Play,Dual EDS 502 Direct Drive, (AC) / 220 Volt
Tonearm: Distortion free Ultra Low Mass (ULM) mounted in a 4 point gimbal tip bearing. 221mm, 160pF capacitance, Stylus Pressure: 0-3 grams
Cartridge Type: ULM, but can be fitted with a standard 1/2" cartridge with the use of an accessory adapter.
Dimensions : 440 x 137 x 390 mm / 17.3 x 5.4 x 15.4 inch
Recently I got few good old Hindustani and Jazz records
1.
Title Amjad Ali Khan - Prisoner of Conscience - ECSD 2864
Artists Shafaat Ali Khan & Amjad Ali Khan
Sarod Amjad Ali Khan Tabla Shafaat Ali Khan
2.
Title: Ravi Shankar - Sitar Gat - EASD 1307 Sitar Gat
Raga : Abhogi Kanada & Raga : Tilak Shyam
3.
Title: Ali Akbar Khan ? From the Concert Hall
Sarod Ali Akbar Khan Tabla Kishan Maharaj
4.
Parween Sultana & Ustad Md. Dilshad Khan ? A Marvellous Jugalbandi
Tabla Walmik Dhonde Vocal Md. Dilshad Khan, Parween Sultana
5.
Title: Ahmad Jamal Quintet, The ? Listen
Label: Agro USA, PYE-JAZZ NJL 32
Country: London `Released 1961 Genre: Jazz
6.
Title: The Erroll Garner Trio Music Maestro, Please
Few Rare records added to my collection recently
Plame?ci/Flamingo/ & Marie Rottrov ? 75
Label: Supraphon ? 1 13 1695, Gramofonov Klub ? 1 13 1695
Format: Vinyl, LP, Album, Limited Edition
Country: Czechoslovakia
Released:1976
Genre: Funk / Soul, Jazz, Rock
Style: Jazz-Rock, Jazz-Funk, Pop Rock, Funk
Recorded At Studio Dejvice
Czech soul/funk/pop group. Formed in 1966 in Ostrava, led by Richard Koval?k until his death in 1975.
During this first period the groups lineup was essentially identical to the nucleus of the Ostravsk Rozhlasov Orchestr, and many recordings performed by the latter could have been actually credited to Flamingo.19751977 led by bass player Ji? Urbnek. Disbanded in 1989 after keyboardist and 3rd leader Vladimr Figars death.
Between 19731987, due to communist censorship issues, they were mostly credited as Plame?ci (Czech for flamingos),
while serving mainly as backing band for vocalists Marie Rottrov and Petr N?mec.
http://www.youtube.com/watch?v=2r1U6n9cNZI
Eagle On The Moon
Label: Voice Of America ? GXTV 222031
Format: Vinyl, LP 33 1/3 rpm, mono.
Country: US
Released: 1969
Style: Dialogue,
Interview A Voice Of America document.
Written and produced by Michael A. Hanu.
Narrated by Harry Munroe
Voice of America marked the historic moon landing with the radio documentary 'Eagle on the Moon'. The narrator was Harry Monroe with contributions from announcer Frank Oliver and VOA Correspondent Rhett Turner at the launch site in Florida. The program was written and produced by Michael Hanu
Michael A. Hanu, an award-winning scriptwriter and editor for the Voice of America. Mr. Hanu and VOA were bestowed the Peabody Award, recognized as the pre-eminent broadcasting prize, for his script about the lunar landing, known as "Eagle on the Moon.
RADIO NEDERLAND
Dutch by radio
Title: Pronunciation practice
Format : EP
Style : Flexible disk 2 nos
Title: estacion de la alergria [The Season of Joy] 1928-1973
Radio program on shortwave radio broadcast on international Netherlands , Radio Netherlands Worldwide
Format : EP [flexi disk]
The first issue of the Season of Joy was by the Dutch broadcaster PCJJ in 1928.
The Season of Joy spread stopped in May 1940 during the invasion of Holland by Adolf Hitler.
In 1946 Eddie Startz resumed transmissions Joy Station, but this time through the Dutch broadcaster Radio Netherlands
The Romanian Radio And Television Folk Music Orchestra
Format : EP
Label: Electrecord
Country: Romania
Catalogue: C.S. 180
Title: Radio Bucuresti
http://www.45cat.com/record/cs180
Eagle On The Moon
Country: US
Released: 1969
Style: Dialogue,
Anil, whats the secret formula for getting such rare collection.
Where did you find them? How much you paid for this?
