rikhav
- Joined
- Mar 27, 2008
- Messages
- 2,677
- Points
- 113
You really cannot compare a RPi based audio system with a Windows or even a larger Linux based system. A RPi based system cannot act as your main audio system. At best, it will work well with a distributed audio system where you have these systems connected to small bookshelf speakers. Look at amplification in the range of some 25 watts per channel.
Though one can argue - take the SPDIF out, connect to a high end DAC, put a powerful amp......etc etc. But then you are missing the point completely. If you are going to spend so much money and take that effort, why use a RPi at all?
The RPi is, in my mind, ideal for a distributed music system. Just the RPi, connected to a low cost speakers. Use your smart phone and get instant music anywhere. It can be considered as a replacement for the Sonos or systems similar to that.
I am sure in time, the capabilities of RPi will increase. At that time, be ready to throw away 100$ of investment and get a new enhanced version.
Don't look for 'audiophile' grade music here.
Absolutely beg to differ from you
Why cant you use you a RPI for a high end system?
With even a proper pc (windows based or Linux based), one would need an external good quality dac for good reproduction of music
when I need my computer to do just audio and nothing else why cant I use the RPI?
Even for a dedicated pc many use a LPS so what's the harm in spending for a LPS for a rpi even if it costs only 3000 bucks
I don't want to get deep into argument but for me a properly tweaked RPI with a LPS can be as good as any NUC or PC used only as a transport
For proper AUDIOPHILE GRADE MUSIC
