sam9s
- Joined
- Aug 25, 2009
- Messages
- 5,239
- Points
- 113
Its on the higher side, but there is a reason, first the form factor, its compact, it uses notebook RAM and HDD which anyhow are a bit expensive than Desktop versions. If we only take the monitory aspect yes an HTPC can be assembled <17, with HDD and RAM, specially with AMD counterpart, however, the size and the polishness of ZOTAC would not be there.
Decision is yours .....
And it would not be me who would be assembling the PC ..
, I can only suggest the hardware, you have to find someone there itself to assemble it for you. Installing OS and XBMC is not that difficult at all.
Finally yes the remote for Nano should work with XBMC ....
