sixthsense
<Strokes knee-length beard, and casts eyes lovingly back to childhood>
The early turntables after 45/33rpm vinyl was inroduced were dual speed. They also had two styluses. One had to flip the lever for either 78rpm or 33rpm. 78rpm styluses where much more chunky: shellac discs had, previously, been played with needles.
Later, diamond styluses were somewhat elite, so it is possible to encounter a "flip" type cartridge with two 33rpm styluses --- to last twice as long.
IIRC --- applies to all the above! I'd completely forgotten that "singles" were 45rpm!
The TT can do all 3 speeds 33/45/78. Yes the cartridge can be flipped over sideways, but I have no clue what the flip over would do. Never tried it fearing it might break it and then I'll loose even the current playback facility of the TT. Looking at your response it might be for 33 rpm records, as I own none I never needed to flip it. Maybe you can enlighten more.
Edit: I've all 3 speeds, the small ones are 45 and couple are 33 and they all play fine with the TT, so your theory about flipping doesn't hold good. Maybe flipping sideways is for taking out the cartridge ?
