Showcase Your Turntable
Oops. Didn't noticed :o.
I also have pioneer sa-6750 which is stored away. A Technics player which is stored away too. HMV Fiesta given by a Parsi Lady and couple of Shure 44 cartridges. I think should play them occasionally.
Regards.
That amp looks monstrous!
The HMV Feista, first one was my Dad's TT, bought back in '75. Hence, its now my prized possession. I tasted the first vinyl blood on this TT only, during my childhood.
All other TTs have been acquired by me later.
Could you please share the model for the Technics TT?
Saket
Yes the amp is heavy. But strangely didn't liked the sound. May be will try different speakers in near future.
No high end can re-live those moments.
It is SL-2000.
Regards.
haisaikat, the LPs are beautifully cared. Do you put the records inside of the original jacket or behind the original jacket (but inside of the outer sleeve) ?.
Thank you,
regards,
sunder.
I keep aside original inner jacket and instead put poly-lined acid free inner paper sleeves
Then slide them into the cardboard outer jacket and finally there is the outer poly jacket that minimizes scratches / tears on the hard vinyl publication cover
Hi Dileepboyi,
I was in the same position as you a few months back when i started looking for an entry into Vinyl. My two cents based on the last few months experience are :
1. Read HFV posts to become a theoretical champ on the vinyl front, within a couple of days you will be spouting MM , MC , DIY phonostages, old idler drive restorations and what not :lol:. On a serious note the kind of information that you will get on browsing the old threads of this forum you wont get anywhere.
2. Do not think about the new budget tables, I took the oft repeated advise on this forum and went for an old manual belt drive TT. My friend on the other hand bought a new semi automatic TT, in the same amount of money I got a better TT a far better cartridge and a few LP's as well. Also to my immense satisfaction my system sounds much better than his.
3. Do not buy anything (TT, records) without seeing & experiencing it first, if in doubt do not buy. Keep your money safe do more research and buy a few days later.
4. In Delhi at least all established sellers of TT's are asking for 2 -3 times their price especially in case of DD's, but you can still get a decent table for what your budget is if you search hard.
5. The forum members are really helpful and am very sure that your local city members will be able to sort out your issues fast.
Sorry for the long post:o
Thanks for suggestion and experience.
Boyireddy
