Sony MHC-GZR888D
cnusangam16
Hyderabad
I have purchased Sony MHC-GZR888D, I wanna play the video files with USB, but it is not reading the video files, where as I can play the MP3 songs.
Also when I play cd's or DVD's, it is taking lot of time to read and some times its hanging. Is there any solution.
Thanks in advance.
Srinivas
Your system has limited video format support for USB playback, check the product manual or the Sony website to find the formats that your system supports. If the format of your video files are not supported then you can convert them into some format that your system supports with some video conversion software.
The system should not have any problem playing standard DVD or CDs. Usually some players have problems like slow loading and hanging when you try to play CDs or DVDs which were burned. What type of discs did you play when you encountered this problem?
