M
mpw
Guest
I'll send you the bill.hyeah:
i knew it
which is why i offered :cheers: and not the bill for a drink :lol:
rgds
My sister works for BASF and she has used this for soundproofing her kids rooms. She vouches that they work very well. She can buy them very cheap (practically free) direct from BASF and I've requested her to bring a lot for me when she visits us next. I'm waiting eagerly!!!I'll give you a free tip which could earn me more beer:
Look up Basotect. They are sold retail under different brand names - Mr. Clean etc. Considering what they can do, they are inexpensive. Line the inner walls with these. Then stuff the box. If you use these, you can get away with using 0.75" thick walls too.
I think he's talking about NOT building the sub and doing what he suggests instead. No?Hari bhai
Let's get the woofer done and then we look at what's next.
One step at a time..
Rgds
Not really the same thing. You don't need to figure out what the box dimensions would be et al. The vendor, GR Research is providing you the exact dimensions. All you have to do is cut the MDF sheets and fix them.Even if i were to buy that kit ( which i will not ), i am afraid i would have to go thru the same thing = to buying a good driver and a good plate amp separately and figuring out the cabinets etc.
Designing a subwoofer from ground up and subwoofer integration are two different things. One doesn't need to design a subwoofer to figure out how to integrate a subwoofer. Don't understand your POV.i think it better to go thru this learning curve than sit on the sidelines passing comments on "subwoofer integration".
I'm sure you understand what a proven design is.Lastly - what is a proven design captain ??
That's precisely why you should exercise an available option of playing the already existing subwoofer in your set up rather than building something grounds up and later realising that it doesn't work for your room.The design maybe proven but the workability for me / you in our rooms is not.
I'm sure you understand what a proven design is.![]()
Tell me, how would you know that the one you are trying to build would work in your room?![]()
As mentioned in the thread the driver and the amp are here already.
I have no intention to buy even in a kit form as i think i can get it done at a better cost with all due respect to GR research / Rythmik etc..
Your sub , hopefully, is rolled off below 100Hz at ( at least ) 24dB/octave . You don't want any low frequency male vocals to come out of it.
